Need Help Picking Between Motherboards
Solved by Jurrunio,
The one with MSI board. the boards are pretty much the opposite of each other. The MSI board has no optional extras like RGB header, all it has is a solid VRM. same fan headers, some ports, that's it. The Asrock board has RGB headers, has SLI support, has Wifi and BT, but a low end VRM. imo it's like buying a utilitarian vehicle like an old Jeep, versus buying a riced out van.
