Hi, I'm looking to build my first computer, I'm not looking to play AAA games or anything fancy, just silly stuff like surgeon simulator, that kind of things, I'll mostly be using it for z brush and editing that sort of stuff. My budget is max £500 (not including monitor) I know it's not a big budget. I'm not sure whether to get a Ryzen 3 2200g and use the integrated graphics or whether to get a graphics card, I know in an ideal world I'd be best off with a graphics card but is it worth it with the sort of things I will be using it for.
https://linustechtips.com/topic/1050579-stuck/
Are you comfortable going used? Also I am using a Ryzen 2200G and it works fairly fine for older AAA games, AAA games at low 30fps, or simplier games. The 2200g is not super stong at more editing type stuff though. If your really on a budget maybe go for a 2400G
https://linustechtips.com/topic/1050579-stuck/#findComment-12445528
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1050579-stuck/#findComment-12445548
[PCPartPicker part list](https://uk.pcpartpicker.com/list/M9KDWD) / [Price breakdown by merchant](https://uk.pcpartpicker.com/list/M9KDWD/by_merchant/)
Type|Item|Price
**CPU** | [AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor](https://uk.pcpartpicker.com/product/RkJtt6/amd-ryzen-3-2200g-35ghz-quad-core-processor-yd2200c5fbbox) | £83.50 @ AWD-IT
**Motherboard** | [ASRock - B450 Pro4 ATX AM4 Motherboard](https://uk.pcpartpicker.com/product/PCKcCJ/asrock-b450-pro4-atx-am4-motherboard-b450-pro4) | £76.88 @ Amazon UK
**Memory** | [Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory](https://uk.pcpartpicker.com/product/wQmxFT/team-vulcan-8gb-2-x-4gb-ddr4-3000-memory-tlgd48g3000hc16cdc01) | £53.44 @ CCL Computers
**Storage** | [Crucial - MX500 500 GB 2.5" Solid State Drive](https://uk.pcpartpicker.com/product/ft8j4D/crucial-mx500-500gb-25-solid-state-drive-ct500mx500ssd1) | £62.94 @ Aria PC
**Case** | [Corsair - Carbide SPEC-04 (Black/Red) ATX Mid Tower Case](https://uk.pcpartpicker.com/product/2tTrxr/corsair-spec-04-blackred-atx-mid-tower-case-cc-9011107-ww) | £47.16 @ Amazon UK
**Power Supply** | [Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply](https://uk.pcpartpicker.com/product/FQ648d/corsair-power-supply-cp9020101na) | £50.73 @ Amazon UK
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **£374.65**
 | Generated by [PCPartPicker](https://pcpartpicker.com) 2019-04-01 20:47 BST+0100 |
https://linustechtips.com/topic/1050579-stuck/#findComment-12445550
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor  (£130.97 @ Amazon UK)
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  (£76.97 @ Ebuyer)
Memory: Crucial - Ballistix Sport LT 8 GB (1 x 8 GB) DDR4-3000 Memory  (£38.50 @ Ebuyer)
Storage: Kingston - UV500 240 GB M.2-2280 Solid State Drive  (£34.21 @ PC World Business)
Video Card: ASRock - Radeon RX 570 8 GB Phantom Gaming X Video Card  (£139.89 @ Amazon UK)
Case: RIOTORO - CR488 ATX Mid Tower Case  (£32.21 @ Amazon UK)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£50.73 @ Amazon UK)
Total: £503.48
Generated by PCPartPicker 2019-04-02 03:23 BST+0100
https://linustechtips.com/topic/1050579-stuck/#findComment-12446467
