Hello Hello,
I´m in the search for a new rig but I'm on a budget and don´t really know what parts to chose. I already have an MSI gtx1050ti and was thinking about moving that into the new computer just to save a few bucks to spend on outer part (will buy an rtx2060 or gtx1660 when I have the money). Is that a valid option so I can get an AMD Ryzen 7 2700x (or a good Intel). I mean running a lower tier GPU for a while isn't that bad if I get a good CPU that will not be in need of change in a while is better than a decent CPU and a decent GPU.
The budget I have is around 860 USD and I already have both GPU and chassi.
Any ideas on what parts to get or any outer thoughts on it?
https://linustechtips.com/topic/1050506-first-full-build/
Whats the goal of this PC? If you're just gaming, you won't need a 2700. What resolution and refresh rate are you planning to play on?
https://linustechtips.com/topic/1050506-first-full-build/#findComment-12445008
Well, I will mostly use it for CAD software and other renderings, and it would be nice to use my 144Hz 1440p monitor to its full power in games.
https://linustechtips.com/topic/1050506-first-full-build/#findComment-12445046
The 2700 would save you money and perform as good in workstation tasks- but would hold you back in high refresh rate gaming.
https://linustechtips.com/topic/1050506-first-full-build/#findComment-12445096
I'd venture to say the 2700 would be better for workstation tasks, since it has higher multi-thread performance.
2 minutes ago, Slottr said:
You can get cheaper RAM and SSD.
WD Blue is around $52 last I checked, and Kingston should be even cheaper. G.Skill still has $88 2x8 3000Mhz on Newegg, I believe.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1050506-first-full-build/#findComment-12445117
I thought it would be helpful to let you know that some Seagate devices of the same model and capacity can run different RPM speeds, you can check the part numbers/revision number here and verify what RPM was assigned:
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/1050506-first-full-build/#findComment-12445547
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor  ($375.89 @ OutletPC)
CPU Cooler: Thermalright - Macho Rev.B 73.6 CFM CPU Cooler  ($49.90 @ Amazon)
Motherboard: Gigabyte - Z390 GAMING SLI ATX LGA1151 Motherboard  ($152.23 @ Amazon)
Memory: GeIL - SUPER LUCE RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  ($89.99 @ Newegg)
Storage: Crucial - P1 500 GB M.2-2280 Solid State Drive  ($69.99 @ Adorama)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Power Supply: Antec - Earthwatts Gold Pro 750 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $852.98
Generated by PCPartPicker 2019-04-01 22:29 EDT-0400
https://linustechtips.com/topic/1050506-first-full-build/#findComment-12446480
Well, looks like the i7-8700K and the i7-9700K isn´t far apart in price and de 9700K is a bit better (still slower than Ryzen 7 2700x in multitasking).
So my follow up question is. Wisch one should I go for?
  1. i7-8700K
  2. i7-9700K
  3. Ryzen 7 2700x
I´m up for debate on if there is anything I have missed while reading up on these CPUs.
https://linustechtips.com/topic/1050506-first-full-build/#findComment-12447713
