http://www.ebay.co.uk/itm/Razer-Blade-14-Inch-Gaming-Laptop-/321238332518
That was all I was able to find with a quick search.
Case = Bitfenix Prodigy, Motherboard = P8Z77 - I Deluxe, CPU = 3570k @ 4.2GHz, RAM = 2x 8GB G-Skill Ripjaws, GPU = Sapphire 7950 Boost Edition, Storage = 256GB Samsung 840 Pro.
https://linustechtips.com/topic/105023-razer-blade-14/#findComment-1404255
You can't :( Razer has only launched it in the U.S and Canada (might only be the U.S...).
This is what I know so they might have launched it elsewhere now. It will though void warranty to have it shipped from a friend in the U.S. for example.
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/105023-razer-blade-14/#findComment-1404264
You can't get it in Europe because Razer are buttheads.
ヽ༼ຈل͜ຈ༽ノ raise your dongers ヽ༼ຈل͜ຈ༽ノ
It feels as though no games ever leave the BETA stage anymore, until about 3 years after it officially releases. - Shd0w2 2014
https://linustechtips.com/topic/105023-razer-blade-14/#findComment-1404296
You can't :( Razer has only launched it in the U.S and Canada (might only be the U.S...). Could I get one if I went on holiday to the us and ordered one their would that work?
https://linustechtips.com/topic/105023-razer-blade-14/#findComment-1404327
Where can you get a razer blade in the UK?
At your local home timber and hardware store. :D:P
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/105023-razer-blade-14/#findComment-1404343
Also in Australia
        ELEPHANT SEALS EVERYWHERE!
https://linustechtips.com/topic/105023-razer-blade-14/#findComment-1404349
