Hey, I've updated my build to have better cooling. PC Part Picker says it has no compatibility issues but I was wondering if the fans will all work correctly, the case comes with 2 fans but I think it needs a extra case fan so I added a extra one?
CPU: Intel - Core i5-9400F 2.9 GHz 6-Core Processor  ($249.70 @ Newegg Australia)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($48.68 @ Amazon Australia)
Motherboard: ASRock - Z390 Pro4 ATX LGA1151 Motherboard  ($178.20 @ Newegg Australia)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-2666 Memory  ($147.64 @ Amazon Australia)
Storage: Intel - 660p Series 1 TB M.2-2280 Solid State Drive  ($170.50 @ Newegg Australia)
Video Card: MSI - GeForce RTX 2060 6 GB VENTUS OC Video Card  ($556.60 @ Newegg Australia)
Case: Corsair - Carbide Series 275R (Black w/Tempered Glass) ATX Mid Tower Case  ($111.00 @ Austin Computers)
Power Supply: Corsair - CXM 650 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($108.90 @ Newegg Australia)
Case Fan: be quiet! - Pure Wings 2 120 PWM 87 CFM 120mm Fan  ($37.33 @ Amazon Australia)
Other: Acer KG271A 27inch 144Hz FHD LED Gaming Monitor  ($329.00 @ Scorptec)
Total: $1937.55
Generated by PCPartPicker 2019-03-31 19:26 AEDT+1100
https://linustechtips.com/topic/1050102-pc-cooling-advice/
A case fan is a case fan, as long as your case has empty bays they'll work.
Btw I initially looked at your build and thought $2000 for that, wtf? Then I noticed Australian Dollars. You guys really do pay for your stuff, it's more expensive than here in England.
Main Rig:-
Server:-
https://linustechtips.com/topic/1050102-pc-cooling-advice/#findComment-12441629
2 minutes ago, glenalz81 said:
Seems that you're kinda ripping yourself off with the i5/z390, maybe not ripping yourself off but not getting as much performance as you could with 2k.
Do you have any advice on how I could maximize performance with this build and a $2000 AUD budget, should I get a different cpu or something?
https://linustechtips.com/topic/1050102-pc-cooling-advice/#findComment-12441637
Swap the Z390 for a B360 and use the money saved to buy a better CPU.
Main Rig:-
Server:-
https://linustechtips.com/topic/1050102-pc-cooling-advice/#findComment-12441640
Sure,  get a 2600 + B450 then get the Ventus 2070,  try and get RAM a little faster, 3000/3200
Comes out to around $2038
And performs around  25% better.
https://linustechtips.com/topic/1050102-pc-cooling-advice/#findComment-12441642
Not cheaper CPU but cheaper board that's good
Vega 64 performs just below the RTX 2070, while being $100 cheaper. Just as good value as the RTX 2060 imo, just trying to fit more performance into the budget.
Changed the case in an attempt to match the white motherboard (limited success)
Change PSU to uh, save a little bit of power? Not sure about how expensive electricity is, but Vega is not the best for saving power.
A lot of fans to use up all the space
Freesync monitor, also VA instead of TN (though it is slightly curved)
Desktop benching:
https://linustechtips.com/topic/1050102-pc-cooling-advice/#findComment-12441656
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($250.00 @ Shopping Express)
CPU Cooler: Deepcool - LUCIFER K2 81.33 CFM CPU Cooler  ($59.00 @ Skycomp Technology)
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  ($149.00 @ Shopping Express)
Memory: Crucial - Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3000 Memory  ($131.46 @ Amazon Australia)
Storage: Crucial - P1 1 TB M.2-2280 Solid State Drive  ($196.35 @ Amazon Australia)
Video Card: Gigabyte - GeForce RTX 2070 8 GB WINDFORCE Video Card  ($749.00 @ Umart)
Case: Silverstone - Primera PM02 (White) ATX Mid Tower Case  ($89.00 @ Scorptec)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($119.00 @ Austin Computers)
Monitor: ViewSonic - VX2458-mhd 23.6" 1920x1080 144 Hz Monitor  ($199.00 @ Umart)
Total: $1941.81
Generated by PCPartPicker 2019-03-31 23:11 AEDT+1100
https://linustechtips.com/topic/1050102-pc-cooling-advice/#findComment-12441845
