Need Help Choosing
Go to solution Solved by Dedayog,
Just now, Eastman51 said:
Don't.
NVMe vs SATA for games and boot drive is negligible. You would notice no discernible difference between the 970 EVO and a $20 SATA SSD as a Windows boot drive.
Oh, and NVMe has poor value vs SATA in terms of capacity:
     - 500GB Samsung 970 EVO = ~$130
     - 1TB WD Blue SATA SSD (M.2 or 2.5") = ~$130
The WD is actually a very nice $120 even.. I'd grab this
https://smile.amazon.com/Blue-NAND-1TB-SSD-WDS100T2B0B/dp/B073SB2MXT/ref=sr_1_5?keywords=wd+blue+1tb&qid=1553884357&s=gateway&sr=8-5
So I'm upgrading a pre-built pc I've had for about a year, I was looking at getting an NVME SSD, I also plan on putting on another 8gbs of ram, but I don't need help with that.
CPU: Ryzen 1700x
GPU: Radeon rx580
RAM: 8gbs of DDR4 at 2400MHz (Future 16gbs)
Current Storage: 1 tb Hard drive
Motherboard: Some non-branded shit dell one, but it does have a PCIe, so I think I should be good
(Bot are 500gb versions) I was deciding of whether to get a Samsung 970 EVO Plus Series($130) or a Samsung 970 PRO($160)
The Evo is 3500read/3300Mb/s write TBW at 600
The Pro is 3500read/2700Mb/s write TBW at 1200
I was wondering if the 600Mb/s write speed difference would be noticeable with my current pc specs.
I also wanted some opinions on TBW and if 1200 TBW is excessive? I kinda want the ssd to last (5-7) years and I'll be using it as my main drive for games/os. But I'll probably still keep files and pictures on the hard drive.
Thanks For The Help.
https://linustechtips.com/topic/1049574-need-help-choosing/
No, it won't. for most people, SATA vs NVMe is barely noticable in day to day use
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/1049574-need-help-choosing/#findComment-12437576
CPU: Ryzen 1700x
GPU: Radeon rx580
You don't need anything more than a SATA SSD in M.2, let alone a 970 EVO Pro.  NVMe doesn't benefit gamers over SATA.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1049574-need-help-choosing/#findComment-12437577
Don't.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1049574-need-help-choosing/#findComment-12437601
Don't.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1049574-need-help-choosing/#findComment-12437607
1 minute ago, jstudrawa said:
They've gone on sale then. Last I checked they were $127
*GPU Test Bench*
https://linustechtips.com/topic/1049574-need-help-choosing/#findComment-12437613
