Every folder on my system is suddenly "Read Only"
Solved by Steven Porter,
The problem has been fixed thanks to good ol' trial and error. After moving the drive to a different USB port, it's now copying fast and reliably as it did before. This doesn't really make sense to me, unless the other port or hub is failing, but I have other drives on that same hub that are still working fine which leads me to believe that the hub is ok.
Oddly, all of the folders still say "Read Only" but other than that it seems things are back to normal.
