I purchased a A-10 5800K after Christmas expecting to play games on medium at decent frame rates but it doesn't I have the money for a SAPPHIRE RADEON HD7950 3GB FLEX OC but I do not know with my CPU being an APU if I can even use a GPU. Help please!
https://linustechtips.com/topic/10491-help/
As far as I know it should work. You used to get an option to XFire the two on some combo's, but not sure that still exists. But, plugging in your external GPU should simply disable the internal gpu on the chip.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/10491-help/#findComment-112700
https://linustechtips.com/topic/10491-help/#findComment-112987
