Hi all,
I've been battling an issue with my computer for some time now. I had a perfectly working setup for about 6 months:
Asus B350 Prime
Ryzen 1600
Samsung 960 Evo
Some RAM
other hardware (Already disconnected and reconnected everything to no avail.
Issue is that I moved house and setup my PC and it wouldn't boot. M.2 doesn't show in BIOS but I think that was normal given my reading online.
Sent the mobo back to reseller, and was sent a new one. Same issue.
Sent it back again, and they claim track damage, won't replace or repair.
Anyway....I bought another B350. Plugged everything in, had some issues getting windows to boot, but it did! Once I removed the other storage devices attached to SATA ports, it eventually booted.
Moved the PC into place, bam, no boot.
I AM SO FRUSTRATED! I'm a very savvy technician. I usually work everything out in a few minutes/I've done something stupid and I resolve the issue. I don't know what else to check.
The SSD works fine on an external NVMe SSD caddy. The Mobo boots into BIOS no issue, updates etc. There are no errors on any tests I've run. GAH!
Help a sad man. Please.
https://linustechtips.com/topic/1048744-baffling-issue-with-mobo-ssd/
Maybe look at if you have a PCIE block on certain lanes when certain SATA posts are active. This is true of the ASROCK B450 PRO 4. What board are you on now?
My Current Build: https://uk.pcpartpicker.com/list/36jXwh
CPU: AMD - Ryzen 5 3600X | CPU Cooler: Corsair H150i PRO XT | Motherboard: Asus - STRIX X370-F GAMING | RAM: G.SKILL Trident Z RGB 2x8Gb DDR4 @3000MHz | GPU: Gigabyte - GeForce RTX 2080 Ti 11 GB AORUS XTREME Video Card | Storage: Samsung - 860 EVO 250GB M.2-2280 - Sandisk SSD 240GB - Sandisk SSD 1TB - WD Blue 4TB| PSU: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply | Case: Corsair - Corsair Obsidian 500D RGB SE ATX Mid Tower Case | System Fans: Corsair - ML120 PRO RGB 47.3 CFM 120mm x 4 & Corsair - ML140 PRO RGB 55.4 CFM 140mm x 2 | Display: Samsung KS9000 |Keyboard: Logitech - G613 | Mouse: Logitech - G703 | Operating System: Windows 10 Pro
Just saw this on ASUS, what SATA port are you plugged in to?
2*When a SATA / PCIE mode M.2 device is installed, the M.2 Socket shares bandwidth with the SATA6G_5/6 ports.
3*When a SATA mode M.2 device is installed, the M.2 Socket shares bandwidth with the SATA6G_5/6 ports
