Hello! I am a 14 year old building my own desktop for the first time. If you can, could you open my google sheet and see if I am doing everything right and check if theirs anything i am doing wrong! Please, any help is a lot.
google sheet pc build
Thank you!!!!!!!!
https://linustechtips.com/topic/1047240-help-please-custom-desktop-build/
the total cost is twice your budget
Desktop benching:
8 minutes ago, Firewrath9 said:
use pcpartpicker, it will be a lot cheaper. also, get a 2700x, its much cheaper, and can be better than a 9700k.
also, you can fit a 2080 in that budget, and get different ram, etc.
Even a 2700 is good enough, he’s 14, I’m pretty sure he is not gonna be running physics simulations or rendering 4K videos, so technically a 2600 should be good but yeaaaa
considering his pfp is fortnite I think it’s safe to assume this will be used to play fortnite, in thatcase an rx 580 should be good enough
OP should include what he needs it for, otherwise I have to go off the assumption he will use it for fortnite and apex, since those are all the rage with 8-14 year olds these days
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
i sometimes play fortnite, i stream and record toooo
Thanks!!! But is all the parts like compatible
If you put them onto PCPartpicker, it'll tell you. At a glance, they look compatible.
Putting it on PCPartpicker will help others compare builds and budgets better.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
We'd also like you to copy/paste the permalink generated by pcpartpicker so we won't have to open your spreadsheet
Primary PC:
PSU tier list
How many watts do I need?
Something not added from your spreadsheet:
Keyboard: definitely not Razer, durability sucks in the past and new stuff havent proved themselves.
Wifi: dont need it, the motherboard comes with the function
Anti-static wrist wrap: That's stupid, just dont rub yourself on stuff made of fibre constantly when you're building
Power plug: buy if you need it
Desktop benching:
Don't You need the Wifi adapter because, i cant connect Ethernet and the drivers wont be installed for the WiFi?
the board comes with a Wifi card that fits into the slot next to the rear i/o
Desktop benching:
6 hours ago, Awesomeguy900 said:
Don't You need the wiki adapter because, i cant connect Ethernet and the drivers wont be installed for the WiFi?
So i don't need to install any drivers for the wifi?
idk, but that's not a problem for now.
Desktop benching:
