Guys,
I am sure most are now aware that i am about to buy a new rig with me forum spam of late! ha.
I need some advice please, I currently have an MCP655 of around 10 years old (maybe more!) with an EK Top, one of these:
sidewindercomputers_2271_55286635
there is no PWM/Tach on it, just power, i don't know the run hours etc.
I have an EK MultiRes X2 250ML screwed directly into the top of the block, like this:
https://linustechtips.com/topic/1046534-pump-help-please/
So i dont know if it will be worth me investing in a new EK pump and res combo or make use of what i have here, ideally would like RGB to fall in line with the rest of the build but not massively important.
I would also like to save funds but i dont want to just be "Oh that will do"
i am going for a similar build to this:
so i need to be mindfull of how i can mount my current Res&Pump Combo
Perhaps i can use a radiator bracket/mount and get some new RES brackets?
https://linustechtips.com/topic/1046534-pump-help-please/#findComment-12411159
I personally would buy a d5 vario just to avoid having the pump af full speed (purely because of noise) If you don't mind the noise, then let it run til it dies :)
https://linustechtips.com/topic/1046534-pump-help-please/#findComment-12411213
5 minutes ago, Sh4d0wm4n said:
Will the pump i have now has a screw to control running speed to be fair, its set it and leave it. cant be changed once installed as cant reach the grub screw.
Its more a case of if i can mount what i have got now and make use of it.
If it aint broke dont fix it. Pumps dont fail in any spectacular way that would take out other components in the loop. You'll just heat soak and trip Thermal Protection when it does die. But, unless the components were on their way out anyways this won't damage them.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1046534-pump-help-please/#findComment-12411239
Ah alright, that's the D5 vario. So you should be good :)
https://linustechtips.com/topic/1046534-pump-help-please/#findComment-12411242
