Are my CPU temps normal?
Go to solution Solved by emosun,
14 minutes ago, MeNeedTips said:
my cpu is running at 43c under basically no load
considering your ambient temp of the room (which is over 90f) the cpu temp is fine
You're basically blowing hot air through your radiator so i'm surprised it's working as well as it is.
Hi, I built a pc about a month ago and its been operating well since, I've overclocked my ram and gpu and have had a really fun time learning more about computers. I have a Cooler Master MasterLiquid ML240L for a aio cpu cooler, from day 1 I've noticed when my cpu isn't under load my radiator fans are quite loud, I don't really mind as my friends are usually screaming at me through discord anyways, I researched how long aio's last just so I'd be ready for when I need a new one and while looking I stumbled into searching "how to determine if your aio is dead". In doing this I found people basing their cpu temps as a sign for their aio being dead, I live in Australia so its generally warm ambient but I am worried my cpu might be too hot, ambient is about 32-34c and my cpu is running at 43c under basically no load, is this too much? or is this to be expected with a aio?
Specs:
RX 580 8GB Saphire Nitro+ OC (1450 core clock, 2200mhz ram speed)
Ryzen 5 2600
16GB DDR4 @3200 (was 2666)
B450M-A
MasterLiquid ML240L
4x 120mm fans
550w 80+ Bronze PSU
https://linustechtips.com/topic/1046295-are-my-cpu-temps-normal/
Open your door, open a window get some cool air in.  74F is ideal.  No matter what cooling you have it all depends on room temp.  If its 90F then those are actually good temps lol,  Now imagine if its 74F in the room, your idles will go to low 30's and load wont go as high.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
If Australia's end of summer/early fall is anything like up in the U.S. opening any windows/doors is going to make it really hot. Sounds like the OP needs a better air conditioner....if they even have one.
I'm using an MSI motherboard with gameboost enabled and hitting 68C under load, 35-40C idle depending on ambient temp..
CPU: Ryzen 5 2600 4ghz @ 1.35v  CPU Cooler: Mugen 5 Rev b  Motherboard: MSI B450 Gaming Pro Carbon  GPU: Zotac RTX 2060 +150/+1000 Memory: 16GB Viper 4 @ 3200 CL14 Samsung B-die  Storage: 1TB Patriot VPN100 NVMe; 500GB 860evo; 128gb 840pro CaseCooler Master Q500L  PSU: CX750M V2 Operating System: Windows 10 Pro Other: 6 Corsair LL Fans; 2 aRGB Strips
Pushing up to 90 watts with stock wraith stealth cooler.
Okay...
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
33c is with my ceiling fan on highest setting, door and window open, no AC :(. That temperature is about average for this time of year where I live unfortunately.
Thats fine temp beacuse you live in hot a** wether
(Take anything I say with a grain of salt)
[Main Pc] CPU, i5 9600k GPU, Asus Strix RTX 2060, RAM, 16b Team Group Delta RGB, PSU, Seasonic Px-750 plat , Cooler, Cooler Master MasterLiquid Lite ML120L RGB, Storage, 500gb Samsung 950 evo/1tb WD blue/2tb HDD,Case, Enermax ECA3520. + some cooler master RGB fans
[Laptop] Dell G3, i7-8750H (Turbo 4.2 Ghz), Gtx 1050 ti , 8gb 2669 mhz, 128gb nvme ssd, 1tb HDD
[Server]
[Consoles] Pretty much almost every popular one you can think of besides for like Xbox and some Sega Stuff( Playstation especially)
[Mobile Devices] iPhone XR 64gb (Red) gb, iPad Air 2 128gb, Space Grey,  Ipod Shuffle Space Grey
