1070 for 144hz
vishy92
Hi!
I mainly play FPS games like APEX or overwatch. Im planning on buying a 144hz display. Would my 1070 OC be enough for it? Right now im building a new rig. Planning on getting a new mobo (z390) and a 9600K. My question is should I shell out significantly more money in my region for an sli board to get another 1070 for 144hz 1080p down the line or just upgrade the gpu. Im tight on money right now so that extra cost is pretty hard on my wallet.
Cheers
i wouldn't suggest a 1070 sli
tho it sohuld be good enough to run around 144 hertz, tho i would suggest you get a freesync monitor
Do NOT go for sli.
As for the fps, just look at benchmarks of the GTX1070 in those games. You'll probably not see 144 but anything over 60 will give you an improvement already.
I'd look out for a gsync or freesync monitor though
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Damn ninjas...
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
1 minute ago, FloRolf said:
Damn ninjas...
we call them buildmasters (the people that work on the build guide)
yeah definitely going for a freesync monitor. It does work with nvidia cards now if I read it correctly? Unfortunatly I just bought the gpu so an upgrade on that front is miles ahead
yep, as far as i've seen you don't need a "g-sync compatible" or "nvidia adaptive sync certified" monitor for it, so just look around what you can find
btw, quoting is appreciated
Yes, it does work, just has to be over DisplayPort. If the monitor is Freesync over HDMI only then Freesync wont run as Gsync on Nvidia.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
