https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12402900
Just now, Isaac Wisnewski said:
That will work great.
The cheapest you can really go is a gt1030 2GB. It is about 130AUD and meets Netflix 4k streaming guidelines.
The 560 however is a much better choice as it has double the VRAM and is faster all around. Its even capable of playing a few older games. Especially if you use resolution scaling.
https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12402907
New cards or used cards? New cards is basically between GT1030 and RX550, depends on which is cheaper and has the ports.
Desktop benching:
https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12402911
Hi,
I am currently using as my daily computer a Lenovo Laptop that is connected to a cheap Dell hub that is powering my two 4k Monitors. the lag is terrrible. But i cant get away from the big screens.
The Lenovo Laptop has an intel Celeron and 8GB of ram (Used to be 4) and a slow 500GB HDD.
I have an old computer that was given to me. and it at least has a core 2 duo in it with 16GB of ram. but no DP or hdmi. so i still need the dock.
https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12402922
If you buy one of the GPUs mentioned above you have the missing ports so you do not need the dock after that. The black slot seems to be PCI-E, so it should work. Only problem: What height is the slot? maybe you need a slim version of the gpu.
EDIT: Also check if you have enough power from your PSU.
https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12402988
32 minutes ago, Schakal_No1 said:
This one would be low profile and does not need additional power: https://www.mwave.com.au/product/msi-geforce-gt-1030-low-profile-oc-2gb-video-card-ac12153
Will it be able to comfortably run my two 32" 4K monitors?
https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12403068
On 3/22/2019 at 8:56 AM, Paradigm02 said:
I don't think so. Its just powering to screens. Simply browsing Chrome or watching content is more cpu and ram heavy
So if i get into a little bit of gaming later on, what's a good choice for long term versatility.
Thanks
https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12418671
9 hours ago, Isaac Wisnewski said:
Not with your current CPU, or at 4K. You've got high end monitors connected to a super low end machine. If you upgraded to a Core 2 Quad you could run games at 1080p on Medium-ish settings though.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12420924
Hi,
So i have some more dimensions for you. thank you all for your help so far.
I can fit a graphics card that it 170x40x70mm
This means a low profile graphics card at half length.
The explosion slot is indeed x16 PCI-E
lastly. The graphics card cannot require external 8-pin connector as i do not have a modular power supply and have not extra power leads from the current gear in this case.
Thanks Heaps.
Isaac
https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12423073
Hi, i managed to score this 1050 oc card with no external power needed
https://www.mwave.com.au/product/gigabyte-geforce-gtx-1050-oc-2gb-low-profile-video-card-ac00252
https://linustechtips.com/topic/1045625-graphics-card-required/#findComment-12432041
