Hello all,
I am after a bit of help if i may trouble you for a bit of your time on this very wet Saturday evening.
I am about to hit buy on my new build after 7 years, one of my (many) troubles is how to control my cooling.
I am going to have a pair of 360 Rads running Corsair LL120's plus the chassis fans, I Suspect a total of 9 or 10 fans. I Currently control my cooling "Zones" with a Lamptron touch but ideally i would like to do away with that and have a software based fan control solution that i can manage in the same way, IE, Rad1 = Zone 1
Rad2 - Zone 2
and then the rest of the fans in single Zones.
Can anyone point me in the right direction please.
**EDIT**
I would like to also control the RGB of each rad x3 fans in line, So Zone1 and Zone2 be managed
https://linustechtips.com/topic/1045325-cooling-controls/
Are you using all LL120s? If so a Corsair Commander Pro and some Y splitters will work just fine.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1045325-cooling-controls/#findComment-12400262
1 minute ago, Sh4d0wm4n said:
I will not be using all LL's i will have some none RGB Fans in under the hood too, unless that complicates things?
As far as fan speed control it doesn't matter if they are Corsair fans or not. Only the RGB fans would have to be corsair for the lighting aspect. So you would get the best of everything RGB controller for the LL's Fan control for all, and even 4 temp sensors. Plus the ability to expand and add on in the future for lighting.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1045325-cooling-controls/#findComment-12400275
