gotta cut come prices but not too much. got some recommendations?
idk much but hoping to get around 60 fps in titles like overwatch,apex,etc at 1080p mid settings
and is 2x4gb memory better or 1x8gb??
the expected power draw is something around 250 watts do i rly need 650 W power supply??
just point out some dumb choices maybe
and i probably need a wifi card i think
i dont know what case to go with i just chose a random
this is a mess
https://linustechtips.com/topic/1044297-first-pc-build-help/
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.99 @ Amazon)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($79.99 @ Newegg Business)
Memory: Patriot - Viper 4 8 GB (2 x 4 GB) DDR4-3000 Memory  ($58.98 @ Newegg)
Storage: Inland - Professional 120 GB 2.5" Solid State Drive  ($19.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: MSI - GeForce GTX 1660 Ti 6 GB VENTUS XS OC Video Card  ($279.00 @ B&H)
Case: Cougar - MX330-G ATX Mid Tower Case  ($42.97 @ Walmart)
Power Supply: Corsair - CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($54.99 @ Newegg)
Total: $745.80
Generated by PCPartPicker 2019-03-14 10:08 EDT-0400
btw, here is a build that fixed most if not all the issues with the build above, improves upon it, and you get it at a lower price.
https://linustechtips.com/topic/1044297-first-pc-build-help/#findComment-12391813
Motherboard: ASRock - X370M Pro4 Micro ATX AM4 Motherboard  ($74.99 @ Newegg Business)
Memory: G.Skill - Aegis 8 GB (1 x 8 GB) DDR4-3000 Memory  ($44.99 @ Newegg)
Storage: Team - L5 LITE 3D 480 GB 2.5" Solid State Drive  ($49.99 @ Newegg Business)
Video Card: Zotac - GeForce RTX 2060 6 GB GAMING Video Card  ($348.99 @ SuperBiiz)
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case  ($35.99 @ Amazon)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($37.98 @ Newegg)
Total: $757.92
Generated by PCPartPicker 2019-03-14 10:11 EDT-0400
https://linustechtips.com/topic/1044297-first-pc-build-help/#findComment-12391820
36 minutes ago, GoldenLag said:
oh dear god. do not buy this build. for too many reasons to list.
what is the maximum budget?
ok in my home currency its like upto 50,000 rupees = something like 720ish dollars
in short i gotta cut a lotta prices here lol
Edited by veer24
https://linustechtips.com/topic/1044297-first-pc-build-help/#findComment-12391869
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($83.98 @ Newegg Business)
Video Card: XFX - Radeon RX 580 8 GB GTS XXX ED Video Card  ($189.85 @ Amazon)
Total: $660.64
Generated by PCPartPicker 2019-03-14 10:32 EDT-0400
pricing varies form country to country. you are probably looking at something like this.
ill try making something using indian pricing. mostly amazon
https://linustechtips.com/topic/1044297-first-pc-build-help/#findComment-12391876
Total: $660.64
ohhhh thx a lot i had considered a 5%-10% price increase but this is great
i dont rly thing i need a ssd like any way its gonna be a faster loadtime for me and if it doesnt significantly affect my in game performance
any thoughts?
https://linustechtips.com/topic/1044297-first-pc-build-help/#findComment-12391886
any thoughts?
you really want an SSD.
not for games, but for snappiness of the OS and having 2 seperate drives for OS and games. its honestly the best investment you will make.
CPU: AMD - Ryzen 3 1200 3.1 GHz Quad-Core Processor  (₹5379.00 @ Amazon India)
Motherboard: Gigabyte - B450 AORUS M Micro ATX AM4 Motherboard  (₹9050.00 @ Amazon India)
Memory: Patriot - Viper 4 8 GB (2 x 4 GB) DDR4-3000 Memory  (₹7545.00 @ Amazon India)
Storage: Kingston - A400 120 GB 2.5" Solid State Drive  (₹1820.00 @ Amazon India)
Storage: Seagate - Barracuda 1 TB 3.5" 7200RPM Internal Hard Drive  (₹2899.00 @ Amazon India)
Video Card: Sapphire - Radeon RX 570 4 GB PULSE Video Card  (₹15800.00 @ Amazon India)
Case: Corsair - 100R ATX Mid Tower Case  (₹3016.00 @ Amazon India)
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  (₹4196.00 @ Amazon India)
Total: ₹49705.00
Generated by PCPartPicker 2019-03-14 20:09 IST+0530
this is what i could come up with indian pricing, but i know these prices arent accurate when comparing to local stores and online stores in India,
https://linustechtips.com/topic/1044297-first-pc-build-help/#findComment-12391897
Total: ₹49705.00
nahh local stores mostly isnt a option here
and i was hoping not to downgrade the ryzen 5 2600
thxx tho it was very hepfull
https://linustechtips.com/topic/1044297-first-pc-build-help/#findComment-12391911
ye, im unfamiliar with the indian market, but i know you can get better deals than on Amazon. or so ive heard. best of luck however
https://linustechtips.com/topic/1044297-first-pc-build-help/#findComment-12391915
Regardless, here's a few things you really need to do;
  • A better PSU; the CX 450 costs only 3500 rupees, and is way better than that VS stuff you've got going on there.
  • Upgrade your motherboard to the Aorus B450 Elite WiFi, it'll save you ~2000 rupees on getting a wifi card.
  • Get dual-channel memory (2x8GB kit).
  • Drop the cooler, the stock cooler is pretty good.
  • ... and stay away from Amazon. It's got atrocious prices on parts, and buying though online retailers like TheITDepot or MDComputers will significantly reduce the cost of your build (they're alright, I've bought from then countess times).
Also, how about switching to a RX 580? You can get one for around 19000 rupees (lowest price), unlike the GTX 1060 6G which goes for 22000 rupees (lowest price). The performance is pretty much the same, and you can save a few buck this way.
https://linustechtips.com/topic/1044297-first-pc-build-help/#findComment-12392065
