I've noticed that I cannot find an itx case that does not have a space for a gpu , but does have a spot for a power supply.
It seems the only itx cases that don't have expansion slots are intended to only have barrel jack power supplies used with them.
https://linustechtips.com/topic/1044179-itx-case/
Theres the elite 110, only one I can think of though
https://linustechtips.com/topic/1044179-itx-case/#findComment-12390687
You want a case like this then, IN WIN makes some that come with decent bronze rated PSUs, They're basically Flex ATX sized, there should be some updated models with a bronze rated PSU in it.
Stick a Ryzen APU in it and you're golden.
https://www.newegg.com/Product/Product.aspx?Item=9SIA0ZX5PZ7514&Description=IN WIN ITX&cm_re=IN_WIN_ITX-_-11-108-428-_-Product
https://linustechtips.com/topic/1044179-itx-case/#findComment-12390696
