Hello.
Whenever i start a program/game my PC freezes up and my hardrive starts making sounds. it sounds like its starts spinning really fast. and after a few seconds i hear a pretty loud click and then everything starts up normally and works.
Sometimes this also happens when my game has been idle for awhile, and when i come back and move the mouse or something,  it sounds like the hard drive  starts spinning really fast and makes that click sound.
So, i'm wondering if this is my hard drive dying. Or if this is a normal thing in older hard drives.
https://linustechtips.com/topic/1043943-dying-hard-drive/
Yeah, Sounds like shes dying there. Backup your stuff :)
Primary Laptop (Gearsy MK4): Ryzen 9 5900HX, Radeon RX 6800M, Radeon Vega 8 Mobile, 24 GB DDR4 2400 Mhz, 512 GB SSD+1TB SSD, 15.6 in 300 Hz IPS display
2021 Asus ROG Strix G15 Advantage Edition
Secondary Laptop (Uni MK2): Ryzen 7 5800HS, Nvidia GTX 1650, Radeon Vega 8 Mobile, 16 GB DDR4 3200 Mhz, 512 GB SSD
2021 Asus ROG Zephyrus G14
Meme Machine (Uni MK1): Shintel Core i5 7200U, Nvidia GT 940MX, 24 GB DDR4 2133 Mhz, 256 GB SSD+500GB HDD, 15.6 in TN Display
2016 Acer Aspire E5 575
Retired Laptop (Gearsy MK2): Ryzen 5 2500U, Radeon Vega 8 Mobile, 12 GB 2400 Mhz DDR4, 256 GB NVME SSD, 15.6" 1080p IPS Touchscreen
2017 HP Envy X360 15z (Ryzen)
PC (Gearsy): A6 3650, HD 6530D , 8 GB 1600 Mhz Kingston DDR3, Some Random Mobo Lol, EVGA 450W BT PSU, Stock Cooler, 128 GB Kingston SSD, 1 TB WD Blue 7200 RPM
HP P7 1234 (Yes It's Actually Called That)  RIP
Also im happy to answer any Ryzen Mobile questions if anyone is interested!
https://linustechtips.com/topic/1043943-dying-hard-drive/#findComment-12388237
Its dying.
What does Hard Disk Sentinel say?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1043943-dying-hard-drive/#findComment-12388254
Hard drive doesn't look dead, but it has probably gone to sleep, what you are hearing is the spin up time of it coming out of having a nap.
You can change this behaviour by having the disk(s) active at all times;
Control Panel > Power Options
Select the plan you are using, hit change plan settings
Select change advanced power settings
Under 'Hard Disk' Expand the options and it will have an option for 'Turn off hard disk after'
Set this to 0 to keep the drive online at all times and prevent spin downs
Please quote or tag me if you need a reply
https://linustechtips.com/topic/1043943-dying-hard-drive/#findComment-12388419
It was currently set to 20 minutes so this makes sense. Thank you!!
https://linustechtips.com/topic/1043943-dying-hard-drive/#findComment-12388439
No problem, some mechanical drives are very loud and almost sound like a 'latch' cracking when they spin up.
The Samsung Spinpoint F1s are built on older mechanical disk technologies so they are reliable but also very clunky and loud
https://linustechtips.com/topic/1043943-dying-hard-drive/#findComment-12388445
