Best RX 580 for less than 200$?
moadoc19
I am looking for an RX 580 for less than or equal to 180~190$? Any suggestions? + Why are their prices fluctuating too much?
sapphire!! at all cost
no other chose, but dont ask me why.
in the US there are a couple of them at this price point. I usually go for XFX and Sapphire, XFX in particular having a better PCB.
Prices fluctuate because computers determine prices, not a Joe or George writing them down every morning when he's having coffee
Desktop benching:
there are others
tho sapphire does have some great cards...
i suggest xfx, msi (except for armor), gigabyte and asus to look into (arez and rog are the same)
No like I check prices like every day and it is 170 then 190 then 195 and it drops.
and then different brands shuffle around to give you the same price range. Basically, buy when a good card is cheap.
https://pcpartpicker.com/product/MBGxFT/msi-radeon-rx-580-8gb-video-card-rx-580-8g-v1
Is this worth it? or is there any better options for the price?
I'd spend $10 more for this
https://pcpartpicker.com/product/gjM323/xfx-radeon-rx-580-8gb-gts-black-core-edition-video-card-rx-580p828d6
much better cooler, most likely better PCB as well.
Desktop benching:
Why is sapphire so gd then?
      I have the xfx card he linked above great card!
ok, so how is your experience then?
I like Sapphire and XFX better than any other board partner historically, as I have never had issues with either brand.  Ive owned Gigabytes etc - nothing wrong with them, but its always seemed that the XFX and Sapphire cards have the beefiest coolers.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
If you don’t mind using used product then this vega 56 will beat rx580 https://www.ebay.com/itm/MSI-Video-Card-Radeon-RX-Vega-56-Air-Boost-8G-OC-/372626853378
If not, then sapphire rx 580 would be my option
Well, I don't know. I prefer not, I will wait for Navi from AMD. Hopefully, something good comes out.
