Hi all, I need help picking a PWM fan controller for my case, as I'd like to be able to control all four of my case fans as one, and I'm using 3 motherboard headers for my H100i.  I have an ASUS ROG Strix Z390-E and I'd love to know the best fan controller recommendations from you guys.  Thanks much!
https://linustechtips.com/topic/1043822-best-pwm-fan-controller/
For something a bit cheaper, you could look at the Phanteks PWM fan hub.
Edit:
What are you using 3 headers for the H100i? You should only be using 1 for the tachometer lead off the pump. The 2 fans should connect directly to the cooler itself.
Edit:
My H150 came with a 3fan splitter that had to be plugged in separately from the pump, but that should still only be 2 headers
