Change the fan profile settings. 85°C and fan speed at 38% ..that's too low
This, it's waaaaaaay off. Run it with standard settings (you bought a 6950 not a 6970, dead with it), judging from your postings in this thread it doesn't sound to me like you're too comfortable in the world of overclocking (or say "not so standard configs"), so for you it's better to just not touch it at all. If you are not 100% comfortable with applying TIM, check a guide or two out and see if you did it correctly. As for the whole stock versus aftermarket cooler discussion there is some truth to this but in no shape or form as much as some users claim. The stock cooler is perfectly adequate for cooling the GPU, although often noisier and warmer than aftermarket coolers, but never the less perfectly adequate.
Hi jeff, it doesn't matter that you had not OC it, by flashing your HD6950 to HD6970 specs, it'd run hotter. And as K3nny had said, that fan profile is way off, you have to raise the fan speed, no other way around this. I have three cards in TriFire, I'd raised the fan profile for my first and second cards, the top and middle ones, to 70% and it's loud, but it can't be helped since mine are in close proximity to one another. I have a TriFire HD6990 + MSI HD6970 Lightning setup, it does not run THAT hot, temps do hit ~80C under load, but I have so far had no heat related shutdown......
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
I tried setting the fan speed @ 45 percent its a bit loud but it still reaches 90 degrees.
i did replaced the thermal paste again last night,
observed the difference fron thin layer of thermal paste to i think is enough and blob of thermal paste. and i tried not to tighten the screws that much
this is the lowest temp i got so far, this is while furmark is running about 14 minutes on 1080p resolution.
the games dont crash anymore guys.
http://gpuz.techpowerup.com/13/04/27/6ze.png
What temps do you get if you raise the fan speed to around 60%-70% because those temps are still quite high?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
