Hello, i got this problem with my headset. I dropped attachemnts how my mic sounds, when i dont even speak, and sound from headset is like underwater, wobling or something, maybe someone have some thoughts what it can be or had this problem to?
Thank you for help.
record-3-12-2019_12-24-09.mp3
https://linustechtips.com/topic/1043727-headsets-mic-problem/
1 minute ago, syn2112 said:
is the front panel and rear panel separate devices in the Sound control panel thing?
If so then double click on the microphone device, then go to Advanced and change the Format to match the playback format.
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1043727-headsets-mic-problem/#findComment-12386410
