Help Me Find A Case
Go to solution Solved by xKyric,
I've worked in this Phanteks case before and can't say enough good things about it.
https://ca.pcpartpicker.com/product/FCs8TW/phanteks-eclipse-p300-tempered-glass-atx-mid-tower-case-ph-ec300ptgbk
Edit: Thanks for rating this as best answer!
I am currently helping a friend put together a parts list, and we can't find a good case. The case needs to be beautiful, easy for a first-time builder to use, and not have that many visible hard drive bays. The max price is $85.
Here is the parts list:
https://linustechtips.com/topic/1043348-help-me-find-a-case/
Change your motherboard to a B450 Tomohawk and get a Fractal Design Meshify C TG.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1043348-help-me-find-a-case/#findComment-12382847
4 minutes ago, emosun said:
you could increase the case budget if you skipped on buying the nearly 200$ motherboard that you aren't going to use the features of
That is for future upgradability. If you could recommend something with similar upgradeability, that could also be appreciated
https://linustechtips.com/topic/1043348-help-me-find-a-case/#findComment-12382849
"Make sense? Oh, what fun is there in making sense?"
-Discord
https://linustechtips.com/topic/1043348-help-me-find-a-case/#findComment-12382869
https://linustechtips.com/topic/1043348-help-me-find-a-case/#findComment-12382908
