CPU Temps high...
Go to solution Solved by emosun,
check the temp with something other than speccy
SOLVED: Speccy was super inaccurate - I used coretemp and it showed me i was getting 23 Degrees.. For anyone having this issue - i highly advise to use different software to compare!
Hi peeps!
I just got finished building my new build today, second ever.
Although, everything is running great - My cpu temps have got me a little..eh,
I'm currently getting 72 °C (went up to 83 while typing this post) Idle, with just 1 tab of chrome open - i'm pretty sure with my old build i was getting like 40-50/60°C idle.
I decided to try out some liquid cooling and purchased myself a AIO. Everything seems to be installed fine and fans are running , i (think) i heard the sound of liquid being pumped around on startup which i'm sure is normal, right?
Am i going crazy thinking these temps are high? or is there something going on with my cooling..
Here's the Speccy screen i've been using to monitor.
Thanks!
Grim
https://linustechtips.com/topic/1043347-cpu-temps-high/
1 minute ago, emosun said:
if i had to guess i'd say you're doing something screwy with the thermal paste or not mounting your cooler correctly. 75 idle is a bad temp to be at
I applied the thermal paste as a little pea size and it's full contact as i checked. I'm so confused on what's going on - literally about to take out the AIO and put in the free one that comes with Ryzen CPUs..I don't like seeing my temps this high
https://linustechtips.com/topic/1043347-cpu-temps-high/#findComment-12382810
