Hello! I decided on some parts for my mini build I want to do with a water cooled cpu. Here it is https://pcpartpicker.com/user/EJOE123451/saved/bkY4qs    I would have a lot more but I’m having a problem deciding the GPU. I want to get an RTX 2060 but there are no mini versions. So I went to the RTX 2070 but it is way more expensive. So now I’m looking at a 1070. Should I just get the 2070 or the 1070 or wait for a mini itx for a 2060?
https://linustechtips.com/topic/1043227-mini-pc-build-continued/
If you are looking for a budget card, go AMD.
There definitely are mini version of the RTX 2060.
https://pcpartpicker.com/product/QP448d/gigabyte-geforce-rtx-2060-6-gb-mini-itx-oc-video-card-gv-n2060ixoc-6gd
https://pcpartpicker.com/product/BvMwrH/msi-geforce-rtx-2060-6-gb-aero-itx-oc-video-card-rtx-2060-aero-itx-6g-oc
 And I'm pretty sure EVGA has one.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
Here's a great card for the price, and it's only slightly larger than the mini nvidia cards. Just wait for it to go one sale.
36 minutes ago, martward said:
Oh really? Maybe it just doesn’t fit in the case because when I searched rtx 2060 in the search bar nothing showed up
38 minutes ago, martward said:
Oh they’re out of stock maybe that’s why I couldn’t find them on search. Thanks tho!
14 minutes ago, EJOE said:
Which card?
Sorry, I forgot the link. Go for a 580 if that's too expensive.
https://pcpartpicker.com/product/cqfhP6/xfx-radeon-rx-590-8-gb-fatboy-oc-video-card-rx-590p8dfd6
