Posted March 11, 2019 I am looking to upgrade my GPU to a ASUS 2080 OC Edition, will my system be heavily bottlenecked due to my CPU or RAM? For reference I play FPS games such as Escape From Tarkov, Battlefield V, etc Monitor: ASUS ROG Swift PG279Q MB: ASUS Maximus VI Formula CPU: Intel i7 4770K + Corsair Hydro H100i (Clocked @ 4.2GHz) RAM: Corsair CMY16GX3M2A1600C9 16GB (2x8GB) 1600MHz DDR3 x2 PSU: Corsair 860i Platinum This guy insists the i7 4770K will not bottleneck a 2080 TI: https://www.youtube.com/watch?v=jhudkF3GWgQ https://www.youtube.com/watch?v=qKztwJTxujg In theory then it will not bottleneck? What are your thoughts? Link to comment https://linustechtips.com/topic/1043052-will-it-be-bottlenecked/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2019 Yes it will, but are you at maximum stable OC on that CPU? @ around 4.8ghz it will be fine. Stinkpci5 3550. DDR3 1600mhz 8GB. Gigabyte GA-H61N-USB3.0. Sapphire RX 570 Nitro 4GB oc. Noctua NH-L12. WD Black 600GB. Silverstone PSU 1KW. Advent 1440x900 75hz VGA monitor 1ms. Acer Veriton M464 chassis. Self help guide. Link to comment https://linustechtips.com/topic/1043052-will-it-be-bottlenecked/#findComment-12380433 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2019 Author No, 4.2GHz is not the maximum stable speed. I think the max I will reach will be around 4.6/7GHz based on the video linked in the original post. Link to comment https://linustechtips.com/topic/1043052-will-it-be-bottlenecked/#findComment-12380441 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2019 Depends a lot on the games you'll be playing. The 4770k is a very capable CPU but it can't do everything. I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 11 and Fedora Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. PSU tier list How many watts do I need? PSU misconceptions, protections explained, group reg is bad Link to comment https://linustechtips.com/topic/1043052-will-it-be-bottlenecked/#findComment-12380469 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2019 Ubisoft Creed titles and heavy CPU6-8 thread titles can have your CPU past 80% across many cores and can drop GPU usages. #NotallGames #ButSomeHeavyOnes I see it on my 4790k at 4.6Ghz and a GTX1070. 1080p Highest Settings are usually my target still and these are the settings I chase. With lower settings and a higher FPS target, you might see it more often in such titles. For the Most part, well made games suffer none to way less on the CPU being 30-60% usages and ample left for 99%GPU.Its just the Heavy games are being more common to see with many game engines moving to 8thread awareness. Again #NotallGames #AAA I can so max out many games and have 99% GPU all day... But I've said it a few times now, it's not all games. Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz Link to comment https://linustechtips.com/topic/1043052-will-it-be-bottlenecked/#findComment-12380470 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2019 Yes, by a considerable amount. i have RTX 2070 and i pair it with 3770K even though i overclock it to 4.2Ghz the CPU will pinnned itself on 100% GPU never hit 90% in most game (No OC) like rainbow six siege. NMS. Just Cause. Witcher III and considering RTX 2070 is bottlenecked by 3770K the 2080 will surely get bottlenecked by 4770K not significant but in considerable amount Link to comment https://linustechtips.com/topic/1043052-will-it-be-bottlenecked/#findComment-12380615 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
