Put USB with Win 10 first on the boot priority, F10, press "Save" and pray to whatever higher being you believe in for it to work.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1042721-first-time-setup-help/#findComment-12377497
5 minutes ago, PurplDrank said:
This isn’t an official windows usb. I bought a key online and downloaded the windows creation media tool
doesn't need to be offical one, as long as it bootable it should boot into the installer
https://linustechtips.com/topic/1042721-first-time-setup-help/#findComment-12377502
I have my key for windows 10. But my razer keyboard wasn’t working so I plugged it into a new USB port and it was working for a bit and now it is not.
Now or I cannot enter the windows 10 key. I will need to continue without the key for now and use the free windows 10 version
https://linustechtips.com/topic/1042721-first-time-setup-help/#findComment-12377510
You don't need a key to install, you just need the usb.
https://linustechtips.com/topic/1042721-first-time-setup-help/#findComment-12377517
1 minute ago, Electronics Wizardy said:
whats drives do you have in the system?
Id unplug all drives but the one you want to install the os on.
I have an ssd and a hard drive
i unplug whichever from from the drive  itself or unplug from the mother board ?
https://linustechtips.com/topic/1042721-first-time-setup-help/#findComment-12377529
