Case Fans for Lian Li O11 Dynamic White
AmpedUpDad
Okay, so amazingly, the case I really wanted(in title) came in stock on Newegg for a freaking STEAL.
Now, I am looking for some RGB or White LED case fans that are good quality and are going to work well for cooling.
I want to spend 70-90 dollars. Or less, if possible.
And I want a set of 3, or just....3 that I can purchase separately.
Thanks y'all.
Edit: I would really like white casing, as well. To go with the white case.
"Liam" - CPU: Ryzen 3700x Base GPU: EVGA Titan X(Maxwell) RAM: Trident Royal Z 32GB @ 3600mhz Case: Lian Li PC-O11 Dynamic White Cooler: Corsair H150i Pro RGB 360mm Case Fans: Thermaltake Riing 12 Series Whitex6
I thought this case holds 9 120mm fans?
Desktop benching:
Yes, but I am saving some room to get a 280mm aio eventually.
And one day...God willing, I will build a custom loop with 2 360mm rads. Hopefully.
2 hours ago, Firewrath9 said:
I think Deepcool makes some good cheap RGB fans (60$ for a 5-pack)
Got a link?
The thing with fans is that the best performing fans don't have LEDs. My personal choice for a radiator fan, the PHanteks F120MP, is white but doesnt have LEDs.
Also in RGB fans, will you use Corsair everywhere? Because they don't follow open standards and instead goes the Apple way of things. Same for NZXT.
Desktop benching:
I am honestly down with not having RGB fans, but my wife is kinda into it.
I could also be down with white led ones.
Got a link?
Rip, the 5-pack is out of stock, but here the 3 pack (40$, the 5 was 60 D:)
https://www.amazon.com/DEEPCOOL-Compatible-Controlled-Motherboard-Controller/dp/B07HMMQHBH/
here is the 2 pack for 140mm
https://www.amazon.com/DEEPCOOL-Compatible-Controlled-Motherboard-Controller/dp/B077YF3TNC/
they also have aRGB which is the RF120/RF140.
These black and white Artic PWM fans with fluid dynamic bearings seem to be popular, but I don't know a lot about them.
https://pcpartpicker.com/product/cXg323/arctic-cooling-case-fan-afaco120p2gba01
BitFenix and Aerocool make some all white fans, but without LED's. I think there are some kits that allow you to mod any fan into a LED fan. I think I see someone overspending and getting Corsair LED's, though.
