Hi Guys So i recently shifted to a new ISP and i encountered a problem my Wifi is fast on my phone it loads up most content quickly ocassionally it has a issue once in every 3 hours it stutters for 1 minute or so. The Problem is with my laptop it has got heavily Inconsistent Speeds Sometimes pages load up  Super Quick and Sometimes it takes forever. Most Commonly the pages normally show up as "Site cant be reached" and out of nowhere it loads up the site. My plan is a 25Mbps Unlimited and all Speed Tests are showing Speeds ranging between 18-24Mbps
Steam Downloads Always go at 25Mbps
My wifi router is A Tenda Wifi
Dns: www.tendawifi.com(set by ISP guy)
Connection type:802.11n
Laptop wifi adapter is
Qualcomm QCA 9377 and windows says all drivers are up to date
https://linustechtips.com/topic/1042018-connection-issues/
It sounds like the laptop is dying, something is up with it, has nothing to do with your connection.  Play a single player game and youll see.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1042018-connection-issues/#findComment-12372046
In conjunction with Turtle Rig, how old is the laptop?
Crimson Panda
http://pcpartpicker.com/list/g6T8QV
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/1042018-connection-issues/#findComment-12372068
its 1 and a half years old
but it fell from my hand about 2 months back dont know wether it has damaged anything the only damage is physically where there is a minor dent on the body and the hinges are damaged
btw its a dell Inspiron 3567
https://linustechtips.com/topic/1042018-connection-issues/#findComment-12372354
That might explain why.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/1042018-connection-issues/#findComment-12374494
