Hi people! I'm from Argentina and prices are REALLY crazy here.
I need some help to decide in GPU (I'm almost sure I'm going for a B450+R5 1600, 'cause that's the best board there is for the price and for some reason the 1600 costs almost $90 less than the 2600).
So, here's the thing. An RX 570 here can be found (new, and in the place with the best price) at $155, the 580 is $250, and the 590 is almost $400.  That last one if freacking crazy. It's cheaper to buy 2 570 and having them in crossfire than buying a 590, and only slightly more expensive than buying a 580.
For reference, 1050 non-TIs, for some strange, reason are the same price (if not more expensive) than the 570. The 1060 6gb is $285 and the 2060 and 1660TI are about the same price at around $470.
I was planning on expending about $800 on the PC that I'll be using for gaming, some video editing (I'm planning on starting a YT channel) and some work for college (I'm a physics student, and not advance enough to be making crazy calculations, but I might need to do them eventually -but that's for what servers are for, right?-). As I said prices down here are crazy, and about 30-40% higher than in the US.
If you have some recommendation, it'll be highly welcome.
https://linustechtips.com/topic/1041839-first-build-picking-gpu/
How is the used market? Such as used 1070s, 590s or other cards. I'm going to assume the new 1070 and 1660ti there are more expensive than the 590
perhaps a ryzen 5 2400G and just use that for low graphics gaming for the time being until you can save up more for a better GPU? or for prices to drop?
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
570 is not that bad, not as bad as 1050ti.
Yes you can crossfire it.
Almost non-existent. And prices are about the same, only slightly cheaper and no guaranty. The page I'm going to use to buy the PC doesn't currently have a 1070 on storage. And the 1660ti cost the same as a 2060 (around $470).
Prices dropping and Argentina is practically an oxymoron.
I was thinking about that, but wouldn't the performance in content creating drop a lot with a 2400G? I'll likely wait for July to see the new things, as I currently only have $600 saved. I'll have to see how are the new APUs then. But the prices seem air fairly fair (for the 570).
I was watching a video and it seems like 2 570 in crossfire are about the same performance as a 590 in some games. How does that translate to content creation?
If your software can use 2 GPUs it'll be much faster than a single 580 or 590 (similar to how a slower but higher core count CPU wins if your applications use all the cores). Be aware crossfire support in games will be iffy, same as SLI, but usually you can get them to behave decently. A single 570 4GB (or even better, 8GB) handles 1080p high/ultra settings in pretty much everything though, and given it's the most reasonably priced one I'd go for one or two of those.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
