A while ago, I was at my friends house and he had recently gotten a micro-ATX NZXT case and we moved his computer into that. He replaced one of the fans in it and had no use for it so he let me take it. I decided that I would put it in the side of my case to blow onto my graphics card. It has the normal fan plug, but it also has a 2 pin power connector for an LED. I like the look of LED's and I would like to have it, but there is nowhere to plug in the LED power. I was wondering if there is any way to get some type of converter to plug this in just to make my case look better. If not, then it's no big deal; I value the importance of a fan whether it has an LED or not.
CPU: Intel Core i7 4770k @4.3 GHz Motherboard: ASUS Z87-A RAM: Corsair XMS3 Series 8GB @1600MHz GPU: EVGA 660 ti SC Case: Antec Three Hundred Illusion Storage: Seagate Barracuda 1TB 7200 RPM 64MB Cache PSU: Corsair CX500
https://linustechtips.com/topic/104177-fan-led-connector/
wouldnt it be a molex connector?
It isn't they usually have a molex to a few 2 pin connectors so if you have multiple LEDs they work in unison
  • Cooler Master Storm Enforcer
  • I7 3770K @ Stock
  • Gigabyte Z77X-UD5H
  • AMD Radeon R9 290
  • Cooler Master Hyper 212+
  • 16gb Corsair Vengeance 1600mhz
  • 2x 1tb WD Green Drives (RAID 1)
  • 256gb Samsung 840
  • Peripherals
  • Logitech G502 Proteus Core
  • Ducky Shine 3 - Blue LED, Brown Switches
  • Samsung SyncMaster 2443
  • Custom Mousepad http://imgur.com/xJWASQM
  • Logitech G35
  • Altec Lansing Octane 7
https://linustechtips.com/topic/104177-fan-led-connector/#findComment-1393333
I'm looking at it now and it looks like it is the same size as the normal fan plug, but I haven't tried plugging it into anything yet
https://linustechtips.com/topic/104177-fan-led-connector/#findComment-1393362
Is this the connector you are looking for?
Yes, that is the connector.
https://linustechtips.com/topic/104177-fan-led-connector/#findComment-1393381
WORKED IT OUT!
The led is powered the same as the fan, that is the connector to turn the LED on ans off, Jumper it to turn it on or get a switch made for it
  • I7 3770K @ Stock
  • AMD Radeon R9 290
  • 256gb Samsung 840
  • Peripherals
  • Logitech G35
https://linustechtips.com/topic/104177-fan-led-connector/#findComment-1393396
They are standard in Cosmos 2 and CM Storm Stryker. Attached to my built in led switch on Stryker.  Haven't seen them anywhere else, but give me 5 min and see what i can find :)
 Asus Rampage IV Formula | i7 3820@4.3GHz | Asus GTX670 SLI | 16GB Kingston HyperX Black The Gathering edt. | H100 | 120GB Intel 330 | 240GB Intel 530 | Seagate 2TB | Seagate 4TB | CM Storm Stryker | Corsair CX750M
https://linustechtips.com/topic/104177-fan-led-connector/#findComment-1393397
