UPS Suggestions ?
in Power Supplies
3 minutes ago, JohnnyCyp said:Desktop Specs:Hello, i want to buy UPS but i have not idea how many VA and Watt must be. The important in UPS is VA or Watt or both ? I want to connect 5 devices:
Desktop (750W), 27" Monitor, Speakers (200W) PlayStation Pro and Linksys E900 router. What UPS should i buy ?
honestly all you should connect to it is the desktop and monitor and router. so you can save whatever you are doing before it can be lost. the playstation, well, simply put its not as prone to carrying important data that can be lost by a power cut. speakers well, i dont think its worth keeping them on a UPS. they aren't crucial. As if you are in the middle of a heavy workload, you get maybe 3-10 minutes (depending on the size of the behemoth you wanna buy) of full load run time, thats it. you want to keep power draw to a minimum.
I would recommend this one or a similar one: https://www.newegg.com/Product/Product.aspx?Item=N82E16842301561
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab0 -
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
8
derekchan ·
Posted in New Builds and Planning15 -
1
3
7
play_circle_filled
Latest From ShortCircuit:
