So I have my Windforce OC 2080 Ti (GV-N208TWF3OC-11GC) and wanna update it to the bios that raises the power limit.
However after researching just to be 100% sure I won't brick, I can't seem to match up driver numbers, for example; I can't find my current Bios Driver number online at all.
I'm trying to update to this specific bios here because it has the higher limit. (https://www.techpowerup.com/vgabios/204664/gigabyte-rtx2080ti-11264-181014)
I'm also going to upload the backed up current bios incase someone needs it to find the actual version I have.
At the end of the day, I just wanna be 300% sure this won't brick my card if I update to it on my Windforce OC.
Current Bios.rom
https://linustechtips.com/topic/1041531-windforce-oc-vbios-identification-and-help/
does your CPU have iGPU?
Desktop benching:
Just now, Radageine said:
Yes, it's a 9900k
then you're fine. As long as you don't brick the BIOS so hard (never heard of flashing different BIOSes on the same GPU to do that, only when flashing BIOS of different GPUs) that nvflash can't pick it up, you can always reflash by connecting the monitor to the iGPU instead.
oh wait, unless your motherboard doesnt have display out. This usually means it doesnt power the iGPU either.
Desktop benching:
Alrighty, time for me to give it a whirl.
What should I use, is there anything else besides NVflash?
I don't think you need anything else (aside from OC tools you've probably installed already).
Desktop benching:
