13 minutes ago, Ryder1329 said:
i am thinking of running a ethernet cable through my wall form my pc from the second floor down to the first floor where the router is im not sure what length i should get: 25ft, 14ft, 10ft,
Um... get the length you need to run the cable through the wall? In my experience, I've never had issues with cables up to 100ft in length. (as long as they're not cheaply made.)
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/1041263-ethernet-cable/#findComment-12365101
ethernet cable cat6/cat5e/5 limits to 100meters, (328 feet). That depends also on the cable materials, if it passes together with electricity cables (prohibited!!!!!!) etc.
A lot of limitations. If you mean that you will connect 2 or 3 smaller ones to make the distance reach then i wouldnt recomend it! better use 1 straight cable. You dont refer the distance that you need to cover so as an advice, remember to calculate propable corners and bending....and if you are surprised how whole buildings with ethernet work...is because the signal is repowered through switches/routers and other network stuff.
https://linustechtips.com/topic/1041263-ethernet-cable/#findComment-12365628
Buy 100ft and cut it to length and do runs to other devices in the house. Console, other PCs, smart tv, etc.
https://linustechtips.com/topic/1041263-ethernet-cable/#findComment-12365645
Just now, Ryder1329 said:
is cat6 the best
cat6/cat5 is metering mainly the speed that it can accept. if you need 1gbit ethernet then use cat6. The standard for sometime now is 5e that can handle the gbit need. but if you dont want to upgrade in the future or you have equipement that works in gbit then use the cat6. but pay attention to be well shielded. You can use Cat5e/or Cat6 its mainly price the problem between them.
https://linustechtips.com/topic/1041263-ethernet-cable/#findComment-12366029
is this a good one? https://www.amazon.ca/AmazonBasics-RJ45-Cat-6-Ethernet-Patch-Cable-25-Feet-7-6-Meters/dp/B00N2VIWPY/ref=sr_1_3?keywords=cat6&qid=1551876114&s=electronics&sr=1-3
https://linustechtips.com/topic/1041263-ethernet-cable/#findComment-12366037
5 minutes ago, Ryder1329 said:
it is a good one. seems shielded and gold plated edges . a bit hard as they refer in reviews and that means it is good for in wall mounting. pick it up if you like the price
https://linustechtips.com/topic/1041263-ethernet-cable/#findComment-12366059
