The second best way is to drill holes in your walls and floors and get an Ethernet cable installed upstairs. Alternatively, wifi router on the same network.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1041219-need-help/#findComment-12364621
A wi-fi card, or USB adapter? I personally prefer an ethernet cable over these. You could also use a powerline adapter.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/1041219-need-help/#findComment-12364622
Just now, Ryder1329 said:
is that like buying a new router and connecting it to the same network
Yes
Primary PC:
PSU tier list
https://linustechtips.com/topic/1041219-need-help/#findComment-12364630
9 minutes ago, Ryder1329 said:
so this is my first build and my router is downstairs so i cant use ethernet. what is the second best way to get internet?
use powerline addapters
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/1041219-need-help/#findComment-12364634
since routers are to expensive for me would powerline adaptders be better than a network card?
They may well be then.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1041219-need-help/#findComment-12364647
