Hi,
I am sorry to say I am not incredibly knowledgeable about all this technology.
I want to upgrade my PC for gaming and streaming and my current set up is:
AMD FX9590 8 Core 4.7 Ghz
Ram 32GB
MSI 990 FXA Gaming
Strix Radeon RX 480 8GB
Corsair H110i 280MM
Corsair AX1500i
Can I upgrade to a Ryzen?
If so can I keep everything in the setup the same or what would I need to change please?
Sorry I did warn I am not that knowledgeable about this stuff :) ... but I need to get better performance for gaming and streaming than what I get currently. I'm constantly getting frame issues :O
Thanks and appreciate if anyone can help with some answers please.
https://linustechtips.com/topic/1040031-upgrading-my-amd-need-help-please/
In order to upgrade, you'll need new motherboard, ram and CPU. What were you looking to spend?.
You might like this.
Edited by fasauceome
Primary PC:
PSU tier list
How many watts do I need?
1 minute ago, Sovek said:
Motherboard, CPU and RAM would be needed. Ideally on the RAM you want something in the 3000-3200 range.
I don't have a budget per say... just need to know what would be a good setup to upgrade to, considering that if need to upgrade again in a couple years... what would be best to upgrade to?
Need to make it better at performing when streaming and gaming at the same time. If that makes sense :)
The parts list I added above would do nicely, if you see something you'd rather swap you can make a different parts list.
Primary PC:
PSU tier list
