Do Head Units use the same harnesses?
I currently have this head unit
https://www.kenwood.com/usa/car/receiver/kdc-168u/
And I'm going to buy this one
https://www.pioneerelectronics.com/PUSA/Car/DVD+Receivers/AVH-1300NEX
The harness look the exact same and have the same pins. Does this mean I can just plug and play the new one without using an adapter?
Thanks
Specs:
 Gaming PC: i5 3570, 16GB 1600MHz, GTX 780 3GB, Transcend 128GB, WD 500GB, Seagate 500GB, Thermaltake 600W Smart, S340 w/ RGB, Windows 10 Pro
 Server: Xeon E5 2650, 12GB 1600MHz ECC, 8400GS, WD 2TB + 1TB + 1TB, EVGA 500B 500W, Windows 10 Pro
 Laptop: Macbook Pro Retina 2013, i7 4558U, 8GB 1600MHz, Intel Iris Pro 1.5GB, Apple 256GB NVME, Mojave
 Internet: $70/month For 500/100, Actually get 525/102
https://linustechtips.com/topic/1039877-do-head-units-use-the-same-harnesses/
The head unit should come with one of these type of adapters in the box
https://www.ebay.com/itm/Pioneer-Car-Radio-Radio-Connector-Cable-Radio-Adapter-18-pin-Iso-Deh-Keh-/252296461707
Big brown and black connectors are standard ISO connectors that attach to matching connectors on the wiring in the vehicle itself. This was true for my european car, I'm not sure if all locations use the ISO connectors in the vehicle.
Basically if the head unit is new it should come with the adapter from Head Unit Output > Wiring in the vehicle.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
I'm saying that my current radio and the new one have the exact same plug. Can I just use the existing one in my car without adding anything?
Specs:
If I were you I wouldn't. Even if both head units were by the same manufacturer I probably wouldn't.
Without having the pinout of the head units, there is no way to tell if same things go to the same pins.
I'm sure googling the pinouts would take more time than 1 minute to change the adapter cable.
I mean if you want to risk $400 head unit and wiring in your car you can try it.
Haha, thanks. I wont take that risk :P
Specs:
