Charging headphones
Go to solution Solved by Brennan Price,
That should be absolutely fine, your phone should give you a pop-up that says 'X is using power' or something similar. I get that whenever I plug in any USB devices using an OTG cable. Alternatively, you could get a cheap power bank and keep both devices charged.
I have a OnePlus 6T and I am planning to buy the Bullets Wireless.
My question is can I connect an OTG cable to my 6T and a USB C charging cable to the headphones to charge them on the go and essentially turn them into wired headphones while they charge?
Doing it via OTG cable because i dont have a USB C to USB C cable
https://linustechtips.com/topic/1039710-charging-headphones/
IT Manager working in the Education sector.
https://linustechtips.com/topic/1039710-charging-headphones/#findComment-12352125
