Hei guys,
It seems that my monitor does not like the black color anymore on half of the display (pictures attached). The issue is only on certain black colors and you can game fine with it, but if there is a dark room, half is pink-redish (sometimes).
The monitor is BENQ XL2411T - https://pcmonitors.info/reviews/benq-xl2411t/ (nVidia 3D Vision Ready and 144hz - DVI cable, with HDMI is the same).
There is no problem with the GPU (I already checked that).
Is there something I can do or I need a new one?
Thank you for reading my topic! <3
https://linustechtips.com/topic/1039700-strange-issue/
Do you keep your monitor nearby any speakers or magnetic devices? I had a very similar incident when I used my main monitor next to my bookshelf speakers. It developed a purple tint down one side, similar to what yours looks like. Other options to try; a different cable, a different display port, a different monitor. Report back after those have been tried.
IT Manager working in the Education sector.
https://linustechtips.com/topic/1039700-strange-issue/#findComment-12352181
15 hours ago, Saksham said:
check high contrast settings
It is the same before POSTing.
There are no speakers nearby. Tried them all with the same result for this monitor, even different GPUs, computers, cables.
Thank you all for the reply!
https://linustechtips.com/topic/1039700-strange-issue/#findComment-12353572
