Hello every one!
I have a problem and i tried couple solutions and none of them works. I will explain which one.
Before i did a reset on the laptop the battery was working fine. Battery 1 and 2 they were charging both to 100%.
But after the reset i got problem that the battery 1 not charging to 100%. And battery 2 is not present. Like here you can see.
Here you can see that the led of battery 2 is not on.
Every time when i restart my laptop i get this message.
I looked on the internet and i did the next following.
  • Downloaded all the drivers from the manufacture, even the one for battery like here you can see.
  • I followed this forum and didn't help.
  • (Troubleshooting power) I did  also "Control Panel\All Control Panel Items\Troubleshooting\System and Security" than click on "Power" to see if the laptop can detect something. But no there is nothing.
  • I downloaded "Fuijtsu Hardware Diagnostic Utility for Windows" and same result. There is no error.
Who knows what I need to do to fix the problem. Thank you very much for helping.
I have a Fujitsu Lifebook E752 with Windows 10
Sorry for my bad English, if I wrote something wrong and you correct me I will be happy!
https://linustechtips.com/topic/1039344-battery-2-not-present/
