Hi there!
I am new to this whole building a pc thing and was wondering if anyone had any case recommendations for $150 or less, i already have all the other parts which i will list below.
ryzen 5 1600x
msi x470 gaming plus mobo
16gb (2 x 8) corsair vengeance ddr4 @2666 mhz
corsair rm750x psu
msi rtx 2060 ventus
coolermaster ml 120mm aio
1tb seagate barracuda 3.5"
https://linustechtips.com/topic/1039057-need-help-with-a-case/
What kind of aesthetics do you want?
https://linustechtips.com/topic/1039057-need-help-with-a-case/#findComment-12346114
here are some of my recommendations, i.e cases I would have in my build ?
ATX Full Tower: Phanteks Enthoo Luxe
ATX Mid Tower: DEEPCOOL MATREXX 55
IMO I like that bit of bling and high effect-ability to my build.
Good luck with your build!
EDIT: Air flow is definitely better in the Phanteks case, the Matrexx is a cheaper case, which in turn has some cheaper qualities.
BLACK ICE
Intel i7 8700k // EVGA RTX 2070 // 16Gb Ballistix Elite // Asus TUF Z370-PLUS // H115i Pro // ThermalTake 850W RBG // WD Blue 500Gb M.2 // Seagate BarraCuda 2Tb // ThermalTake View 31
https://linustechtips.com/topic/1039057-need-help-with-a-case/#findComment-12346143
Fractal Deisgn Meshify C or Define R6 if you wanna spend a bit more
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
https://linustechtips.com/topic/1039057-need-help-with-a-case/#findComment-12348149
