Has anyone else discovered that with r6 you are now getting lower frames across the board it used to be 144hz dead but is now closer to 65 odd to. in fact this applies to all games pretty much ive tried ddu and that worked till the most recent update of drivers which i think might be the issue
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1038533-r6-frame-issues/
10 minutes ago, LoGiCalDrm said:
If you have already noted the drivers being the cause, install the older version. Or you could try if beta drivers have that issue fixed.
no beta drivers available sadly, only ones from 2017. looks like a driver roll back for me
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1038533-r6-frame-issues/#findComment-12343080
