build I need Build PC
7 minutes ago, Sansanlin said:Thanks for the build, it looks good!
Would be posible to have 16 Gb of ram? dont mind if is a bit more expensive.
The case dont need to be fancy, something focused on performance/airflow would do the trick if it is cheaper, the P300 seens fine to me at this price.
thx to all for you help
It would be possible.
I also made some better decisions in this build which certainly pay off, so try this out (1130€):
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor (€257.90 @ Amazon Espana)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard (€136.99 @ Amazon Espana)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory (€141.82 @ Alternate)
Storage: Crucial - MX500 250 GB 2.5" Solid State Drive (€44.64 @ Amazon Espana)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive (€46.30 @ Amazon Espana)
Video Card: Sapphire - Radeon RX VEGA 56 8 GB PULSE Video Card (€325.15 @ PC Componentes)
Case: Phanteks - Eclipse P300 Tempered Glass (Black) ATX Mid Tower Case (€66.24 @ PC Componentes)
Power Supply: SeaSonic - PRIME Ultra Gold 650 W 80+ Gold Certified Fully-Modular ATX Power Supply (€111.75 @ Amazon Espana)
Total: €1130.79
Generated by PCPartPicker 2019-02-27 19:45 CET+0100
