So I'm wanting to do a pc build for £700 dont mind about going a bit over just hopfully not by much the only things i care about is it being pure amd and theme is white and blue (due to a mouse i got given) tower itself is the 700 but if you know a good keyboard that fits the theme then let me know
https://linustechtips.com/topic/1037809-new-build-help-please/
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  (£144.95 @ AWD-IT)
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  (£79.98 @ Ebuyer)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  (£97.98 @ Aria PC)
Storage: Crucial - MX500 250 GB 2.5" Solid State Drive  (£42.50 @ Aria PC)
Storage: Toshiba - P300 2 TB 3.5" 7200RPM Internal Hard Drive  (£52.99 @ Amazon UK)
Video Card: XFX - Radeon RX 580 8 GB GTS XXX ED Video Card  (£173.00 @ Amazon UK)
Case: Game Max - FALCON WHITE RGB ATX Mid Tower Case  (£47.39 @ AWD-IT)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£46.99 @ AWD-IT)
Total: £685.78
Generated by PCPartPicker 2019-02-25 11:42 GMT+0000
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335583
Total: £685.78
couple small changes
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335590
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  (£89.99 @ Box Limited)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  (£37.59 @ Aria PC)
Case: Fractal Design - Focus G ATX Mid Tower Case  (£46.51 @ More Computers)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply  (£59.98 @ Amazon UK)
Total: £692.50
Generated by PCPartPicker 2019-02-25 11:47 GMT+0000
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335592
Motherboard: MSI - B450M MORTAR TITANIUM Micro ATX AM4 Motherboard  (£104.98 @ Laptops Direct)
Memory: Corsair - Vengeance LPX 8 GB (2 x 4 GB) DDR4-3000 Memory  (£57.18 @ Aria PC)
Storage: ADATA - Ultimate SU650 120 GB 2.5" Solid State Drive  (£17.98 @ Aria PC)
Case: Fractal Design - Meshify C White TG ATX Mid Tower Case  (£79.98 @ Amazon UK)
Power Supply: be quiet! - Pure Power 11 CM 500 W 80+ Gold Certified Semi-Modular ATX Power Supply  (£61.92 @ Aria PC)
Total: £677.58
Generated by PCPartPicker 2019-02-25 11:50 GMT+0000
here you go. one white build
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335601
Total: £677.58
this is below my expectations goldenlag...
you need a wholesome cookie to recover
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335607
tempered glass case my dude. that is why. also a more than 400 watt PSU so that you can actually buy some older high end GPUs in the future.
i do stuff for a reason. also white Mobo.
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  (£53.10 @ CCL Computers)
Case: Phanteks - Eclipse P300 Tempered Glass (White) ATX Mid Tower Case  (£50.99 @ AWD-IT)
Power Supply: be quiet! - System Power 9 500 W 80+ Bronze Certified ATX Power Supply  (£48.52 @ CCL Computers)
Total: £691.50
Generated by PCPartPicker 2019-02-25 12:05 GMT+0000
better?
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335646
18 minutes ago, LukeSavenije said:
if he can verify with ebuyer that the X370 pro supports Zen+ or update it himself with a bootkit, then that will be the best choice. wouldn't go with the Kingston A400 tbh, since the MX500 is only 10 pounds more.
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335652
about the mx500 is a fair point
I'm generally not a big fan of the prime series, that's mostly why
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335659
Just now, GoldenLag said:
you had some "meh" in comparison to what h requested.
like 400 watt PSU. really? like i get somde budget uses, but you had money leftover.
and grey and black mobo.
yeah, there is a 500w version of it listed too, so that can be swapped
i mean... the only mobo that's actually white and any good is the bazooka arctic
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335662
*chough Mortar Titanium is a Tomahawk board with one less heatsink on a VRM we arent going to use
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335666
the X370-Pro was a pretty good budget X370 board for it's time, for 80 pounds it's pretty hard to pass up.
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335691
i won't argue too hard with that
let's keep the option open for both then, as the b450 pro4 isn't bad either
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335695
Total: £691.50
better?
That board has a Silver PCB and Heatsinks.
https://www.anandtech.com/show/13091/analyzing-b450-for-amd-ryzen-a-quick-look-at-all-the-motherboards/19
Shame there is no B450 'Arctic' version.
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335745
its as white as it gets. also Silver goes pretty well with white and they are rather similar.
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12335785
Still not White though, hence the name 'Titanium'.
The Tomahawk Arctic would have been a better option, but I don't think there is a B450 version.
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Total: £0.00
Generated by PCPartPicker 2019-02-25 14:55 GMT+0000
I would just go with the B450 Tomahawk as that has a pretty neutral colour scheme.
https://linustechtips.com/topic/1037809-new-build-help-please/#findComment-12336117
