Silverstone PS15-B TG (M-ATX Case) usd$30.00
Galion
Dimensions
H380mm X W191MM X D350mm, 25.7 liters.
IO : Dual usb3.0 type A, headphones and microphone support, power and reset buttons.
Motherboard support : M-ATX, M-ITX.
Max cpu cooler dimensions support
Air cooler : 152mm in height
Liquid cooler : 240mm
GPU support : 310mm in length, 150mm in width.
One of the smallest and best looking budget case I've seen on amazon, easy to build in and a perfect match for Silverstone's Tundra 02-slim but almost all 240mm AIOs are supported, although it does not come with any rubber grommets or have a psu shroud if you use a modular psu it would still look very clean. PSU support up to 150mm and only a single 3.5 inch hdd and up to dual 2.5 inch drives.
Suggested build for case :
Silverstone PS15-B
Ryzen R5 2600
Silverstone Tundra 02-Slim (install radiator in top vents)
Msi b450m Bazooka Plus
T-force gaming delta 3000mhtz cl16 RGB ram
Adata XPG SX8200 Pro nvme 512gb m.2 - (Boot Drive/Games)
Toshiba 7200rpm 2tb 3.5 inch hdd - (mass storage)
CoolerMaster MWE 650w 80+ gold modular
Front/Exhaust : inwin polaris rgb af fans
As for gpu I have 4 options to choose from.
Galax RTX 2060 1-click OC 6gb
Gigabyte RTX 2060WF oc 6gb
Zotac RTX 2060 twin fan 6gb
PowerColor RX Vega 56 8gb Red Devil - (if you can find one under $350.00)
Best Value Build List
Budget 1080p System (RGB) https://pcpartpicker.com/list/7v2Lmq - (this build comes with two free games with the RX 570)
