CPU Cooling question
Solved by Earnist_,
Just now, bobbobobobo said:I am currently building my first pc and i came across a problem with the CPU cooling and i think this may be because the cooler i'm using(Kraken x72) needs a 10 pin connector to plug into on my motherboard (asus maximus xi hero wifi) but there are none left for me to use because i have used up all of the one at the bottom for front panel usb's and the on button. If anyone could help and come up with a solution that would be really helpful
buy a splitter so you can plug it in or youll need a new cooler if your current temps are bad from that not being plugged in
