rtx 2060 and ryzen 5 2600
stach
Do the rtx 2060 (overclocked) and the ryzen 5 2600 (overclocked) are good together or is one of them a bottleneck?
Should be fine, the R5 2600 is a killer CPU. The Ryzen series 6 and 8 cores are great for gaming (6 cores would be the sweet spot though), only place they struggle vs intel is at about 100Hz or higher or in heavily single core games.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
2 minutes ago, LukeSavenije said:
bottlenecks are a weird word. will it? yes
should you worry about it? no, it's a solid combo
Yee, there's pretty much always a bottleneck somewhere. It won't be anywhere near as bad as my i7 950 with a Radeon VII or 1080 Ti tho (actually swapped to a 660 and then 1050 Ti and am getting better performance, lol) tho so it's not really a concern. Won't even be noticeable.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
The setup I have now is also really bad, I have a intel 3330 with a gtx 1050 and 12 gb or ram (1x4gb and 1x8gb) both clocked to 1000mh?
That's not too terrible, the mismatched RAM is probably the biggest issue (IDK if it'll run in dual channel if the capacities are different), that and the 1050 often struggles due to only having 2GB of VRAM. Still pretty impressive for what it is though, I have one and a 660 (also 2GB VRAM), they punch well above their weight in any properly optimized games, ones that are really VRAM hungry kill them though.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
should I remove the 4gb one?
Then it'd just be 100% guaranteed to run in single channel so all you'd do is lose 4GB of capacity, so probably a negative performance difference AFAIK.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
