So my pc does this thing where it skips splash screen and the screen stays blank for like 5 mins before windows welcome screen I've delt with this problem as a minor inconvenience for a while but my ram speed recently defaulted to 2133 and its hurting me a bit in some newer titles so I wanna set my xmp profile back up but alas no bios splash screen
Please help ( as a side note I do not have windows fast boot on and I also find it odd that my system takes so long to boot being as I have an ssd)
System specs
Ryzen 5 2600
8gb corsair vengeance lpx
Gigabyte motherboard ( can't remember model number)
Asus gtx 1050ti oc edition
https://linustechtips.com/topic/1035081-help/
Did you try clearing cmos?
CPU: AMD Ryzen 5700x  (evga 240 AIO cooling)
PBO Settings:
Boost Override CPU: +200
CO: -17 all core
PPT: 140
TDC:  110
EDC: 150
Scalar: Auto
Mobo: Asrock x570 steel legend wifi ax
GPU: asrock challenger 7800xt 16 gb
Ram: 64 gb @3600 mhz
Case: Fractal Design Meshify C White
PSU: Seasonic Focus GX-1000
Storage: 1tb Samsung 860 ssd, 2tb nvme x2, 2tb Hitachi HDD, 4tb HDD for media, 5tb external
Display: Samsung 27" CHG70 1440p QLED Monitor
https://linustechtips.com/topic/1035081-help/#findComment-12311922
System specs
Ryzen 5 2600
try resetting the bios by removing the cmos battery and putting it back in
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1035081-help/#findComment-12311924
Are you running an overclock and its boot cycling 3 times and resetting the OC?
XMP/DOHCP profiles can do this as well from what I understand.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1035081-help/#findComment-12311927
Clear the CMOS. If that doesn't work you will need to get us the model of your motherboard, which you should have done before posting this. It's quite possibly the only spec we need in this scenario and you didn't list it.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1035081-help/#findComment-12311928
There might be no need to clear cmos.
In Windows hold down left shift then click start > power > restart (keep holding shift until you click restart then release it). If a menu shows click Advanced > Reboot to UEFI firmware, if it doesn't then you're legacy booting and a clear CMOS will be needed.
Main Rig:-
Server:-
https://linustechtips.com/topic/1035081-help/#findComment-12311931
Removed come batter instead of clearing via jumper was able to get into bios  set up xml upon restart it did show splash screen now just waiting to boot which still takes longer then I'm sure it should but this time it's on the windows logo with the loading circle
https://linustechtips.com/topic/1035081-help/#findComment-12312026
Windows complete resets are much slower than shut downs to start up.  Shut down is the new Hibernation mode.  Restart (or clearing your CMOS) requires a full Boot.
https://linustechtips.com/topic/1035081-help/#findComment-12313194
