Linux no sound whatsoever
Go to solution Solved by Guest,
7 minutes ago, losBaumos said:
Ah sorry I think my wording wasn't clear.
So before I tried the kernel update I already tried to unmute everything in the alsamixer but it had no effect.
Now I can unmute stuff and it will work till the next reboot.
Btw to do that correctly in alsamixer you need to:
Press F6 and select the inboard sound card
Press F3 and make sure only output devices are shown
Move with the <- and -> keyboard arrows, with the up arrow you can make the volume lower and higher, if it has an "MM" unmute it with M keyboard key
Make sure you go to the all other way with the right arrow -> since there can be other devices hidden
Also if it still does not work try to remove the firmware we put before
So you are saying it works know but it is muted automatically in reboot?
If this is the case, once you get the correct settings, run
sudo alsactl store
and the setting will be saved and applied on reboot
Hi guys,
Because my Windows was annoying me i wanted to give Linux another shot and installed deepin. Everything worked perfectly fine until I noticed that there was no audio output whatsoever. My first thought was maybe the audio is just muted, but that wasn't the case. So I had a look in the sound options to see weather the audio output was correct or not. The strange fact is that I saw my audio devices and even saw the volume indication under it moving around. I tried to change some settings, but still no effect. So I used a little google-fu and found some instructions to change some settings within the alsa mixer, but they had no effect aswell. I even tried to reinstall alsa, but still no effect. so I thought to myself maybe it's just this Linux distribution so I tried Ubuntu with the same effect. Afterwards I gave Linux mint and Solus a shot and behold -- still  no audio while the symptoms stayed the same. I know that all my cabeling and so on works, cause when I boot from the windows disk all the sounds work just fine.
In case it matters I am rocking an i7 7700 paired with an gtx 1060 and 16gb of ram.
So if one of you could help me I would appreciate it very much.
Greetings
https://linustechtips.com/topic/1034961-linux-no-sound-whatsoever/
Hi,
my motherboard is a Gigabyte Z170X-Gaming 7
my Ubuntu version is 18.10
I am not using any dedicated soundcards and the output from the command is the following (sorry that I post the whole thing, but I am not quite sure what part you needed).
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
	Subsystem: Gigabyte Technology Co., Ltd Intel Kaby Lake Host Bridge
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort+ <MAbort+ >SERR- <PERR- INTx-
	Latency: 0
	Capabilities: [e0] Vendor Specific Information: Len=10 <?>
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 05) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 16
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 0000e000-0000efff
	Memory behind bridge: ec000000-ed0fffff
	Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: [88] Subsystem: Gigabyte Technology Co., Ltd Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16)
	Capabilities: [80] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
		Address: 00000000  Data: 0000
	Capabilities: [a0] Express (v2) Root Port (Slot+), MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0
			ExtTag- RBE+
		DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
			RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
			MaxPayload 256 bytes, MaxReadReq 128 bytes
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
		LnkCap:	Port #2, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <256ns, L1 <8us
			ClockPM- Surprise- LLActRep- BwNot+ ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk+
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt+ ABWMgmt+
		SltCap:	AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
			Slot #1, PowerLimit 75.000W; Interlock- NoCompl+
		SltCtl:	Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
			Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
			Changed: MRL- PresDet+ LinkState-
		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
		RootCap: CRSVisible-
		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Via WAKE# ARIFwd-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Via WAKE# ARIFwd-
		LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
			 EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
	Capabilities: [100 v1] Virtual Channel
		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=1
		Arb:	Fixed- WRR32- WRR64- WRR128-
		Ctrl:	ArbSelect=Fixed
		Status:	InProgress-
		VC0:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
			Arb:	Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
			Ctrl:	Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
			Status:	NegoPending- InProgress-
	Capabilities: [140 v1] Root Complex Link
		Desc:	PortNumber=02 ComponentID=01 EltType=Config
		Link0:	Desc:	TargetPort=00 TargetComponent=01 AssocRCRB- LinkType=MemMapped LinkValid+
			Addr:	00000000fed19000
	Capabilities: [d94 v1] #19
	Kernel driver in use: pcieport
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31) (prog-if 30 [XHCI])
	Subsystem: Gigabyte Technology Co., Ltd Sunrise Point-H USB 3.0 xHCI Controller
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 121
	Region 0: Memory at ed330000 (64-bit, non-prefetchable) [size=64K]
	Capabilities: [70] Power Management version 2
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
	Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
		Address: 00000000fee00278  Data: 0000
	Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd Sunrise Point-H CSME HECI
	Latency: 0
	Interrupt: pin A routed to IRQ 126
	Region 0: Memory at ed34d000 (64-bit, non-prefetchable) [size=4K]
	Capabilities: [50] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
	Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee00318  Data: 0000
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] (rev 31) (prog-if 01 [AHCI 1.0])
	Subsystem: Gigabyte Technology Co., Ltd Sunrise Point-H SATA controller [AHCI mode]
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 123
	Region 0: Memory at ed348000 (32-bit, non-prefetchable) [size=8K]
	Region 1: Memory at ed34c000 (32-bit, non-prefetchable) [size=256]
	Region 2: I/O ports at f050 [size=8]
	Region 3: I/O ports at f040 [size=4]
	Region 4: I/O ports at f020 [size=32]
	Region 5: Memory at ed34b000 (32-bit, non-prefetchable) [size=2K]
	Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
		Address: fee002b8  Data: 0000
	Capabilities: [70] Power Management version 3
	Capabilities: [a8] SATA HBA v1.0 BAR4 Offset=00000004
	Kernel driver in use: ahci
	Kernel modules: ahci
00:1b.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #17 (rev f1) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
	Capabilities: [40] Express (v2) Root Port (Slot-), MSI 00
			ExtTag- RBE+
			MaxPayload 128 bytes, MaxReadReq 128 bytes
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
		LnkCap:	Port #17, Speed 2.5GT/s, Width x2, ASPM L0s L1, Exit Latency L0s unlimited, L1 <4us
			ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk-
		LnkSta:	Speed 2.5GT/s, Width x0, TrErr- Train+ SlotClk- DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range ABC, TimeoutDis+, LTR+, OBFF Via WAKE# ARIFwd+
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
		LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
			 EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
	Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
	Capabilities: [90] Subsystem: Gigabyte Technology Co., Ltd Sunrise Point-H PCI Root Port
	Capabilities: [a0] Power Management version 3
		Status: D3 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
00:1b.2 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #19 (rev f1) (prog-if 00 [Normal decode])
	Interrupt: pin C routed to IRQ 18
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
			ExtTag- RBE+
		LnkCap:	Port #19, Speed 8GT/s, Width x1, ASPM not supported, Exit Latency L0s unlimited, L1 <16us
		LnkSta:	Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
			Slot #22, PowerLimit 10.000W; Interlock- NoCompl+
		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
			Changed: MRL- PresDet- LinkState-
		DevCap2: Completion Timeout: Range ABC, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd+
	Capabilities: [100 v1] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
		AERCap:	First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
	Capabilities: [140 v1] Access Control Services
		ACSCap:	SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd- EgressCtrl- DirectTrans-
		ACSCtl:	SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
	Capabilities: [220 v1] #19
00:1b.3 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #20 (rev f1) (prog-if 00 [Normal decode])
	Interrupt: pin D routed to IRQ 19
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 0000d000-0000dfff
	Memory behind bridge: ed200000-ed2fffff
			ExtTag- RBE+
		LnkCap:	Port #20, Speed 8GT/s, Width x1, ASPM not supported, Exit Latency L0s <1us, L1 <16us
		LnkSta:	Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
			Slot #23, PowerLimit 10.000W; Interlock- NoCompl+
			Changed: MRL- PresDet- LinkState+
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #1 (rev f1) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
			ExtTag- RBE+
		LnkCap:	Port #1, Speed 8GT/s, Width x1, ASPM not supported, Exit Latency L0s unlimited, L1 <16us
			Slot #4, PowerLimit 10.000W; Interlock- NoCompl+
	Capabilities: [90] Subsystem: Gigabyte Technology Co., Ltd Sunrise Point-H PCI Express Root Port
00:1c.1 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #2 (rev f1) (prog-if 00 [Normal decode])
	Interrupt: pin B routed to IRQ 17
	Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
			ExtTag- RBE+
		LnkCap:	Port #2, Speed 8GT/s, Width x1, ASPM not supported, Exit Latency L0s unlimited, L1 <16us
			Slot #5, PowerLimit 10.000W; Interlock- NoCompl+
00:1c.2 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #3 (rev f1) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
	I/O behind bridge: 0000c000-0000cfff
	Memory behind bridge: ed100000-ed1fffff
			ExtTag- RBE+
		LnkCap:	Port #3, Speed 8GT/s, Width x1, ASPM not supported, Exit Latency L0s <1us, L1 <16us
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
			Slot #6, PowerLimit 10.000W; Interlock- NoCompl+
00:1c.4 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #5 (rev f1) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=08, subordinate=40, sec-latency=0
	I/O behind bridge: 00002000-00003fff
	Memory behind bridge: dc000000-ebffffff
	Prefetchable memory behind bridge: 00000000d4000000-00000000d5ffffff
		DevCap:	MaxPayload 128 bytes, PhantFunc 0
			ExtTag- RBE+
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
		LnkCap:	Port #5, Speed 8GT/s, Width x4, ASPM not supported, Exit Latency L0s <1us, L1 <16us
		LnkSta:	Speed 8GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
			Slot #8, PowerLimit 25.000W; Interlock- NoCompl+
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+, EqualizationPhase1+
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
00:1d.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #9 (rev f1) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=41, subordinate=41, sec-latency=0
			ExtTag- RBE+
		LnkCap:	Port #9, Speed 8GT/s, Width x4, ASPM not supported, Exit Latency L0s unlimited, L1 <16us
			Slot #12, PowerLimit 25.000W; Interlock- NoCompl+
00:1f.0 ISA bridge: Intel Corporation Z170 Chipset LPC/eSPI Controller (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd Sunrise Point-H LPC Controller
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd Sunrise Point-H PMC
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Region 0: Memory at ed344000 (32-bit, non-prefetchable) [size=16K]
00:1f.3 Audio device: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd Sunrise Point-H HD Audio
	Latency: 32, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 127
	Region 0: Memory at ed340000 (64-bit, non-prefetchable) [size=16K]
	Region 4: Memory at ed320000 (64-bit, non-prefetchable) [size=64K]
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee00338  Data: 0000
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd Sunrise Point-H SMBus
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Region 0: Memory at ed34a000 (64-bit, non-prefetchable) [size=256]
	Region 4: I/O ports at f000 [size=32]
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-V (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd Ethernet Connection (2) I219-V
	Latency: 0
	Interrupt: pin A routed to IRQ 124
	Region 0: Memory at ed300000 (32-bit, non-prefetchable) [size=128K]
	Capabilities: [c8] Power Management version 3
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
	Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee002d8  Data: 0000
	Capabilities: [e0] PCI Advanced Features
		AFCap: TP+ FLR+
		AFCtrl: FLR-
		AFStatus: TP-
	Kernel driver in use: e1000e
	Kernel modules: e1000e
01:00.0 VGA compatible controller: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB]
	Interrupt: pin A routed to IRQ 128
	Region 0: Memory at ec000000 (32-bit, non-prefetchable) [size=16M]
	Region 1: Memory at c0000000 (64-bit, prefetchable) [size=256M]
	Region 3: Memory at d0000000 (64-bit, prefetchable) [size=32M]
	Region 5: I/O ports at e000 [size=128]
	Expansion ROM at 000c0000 [disabled] [size=128K]
	Capabilities: [60] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee00358  Data: 0000
	Capabilities: [78] Express (v2) Legacy Endpoint, MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
			MaxPayload 256 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkSta:	Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Via message
		Status:	InProgress-
			Arb:	Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
	Capabilities: [250 v1] Latency Tolerance Reporting
		Max snoop latency: 71680ns
		Max no snoop latency: 71680ns
	Capabilities: [128 v1] Power Budgeting <?>
	Capabilities: [420 v2] Advanced Error Reporting
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
	Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Capabilities: [900 v1] #19
	Kernel driver in use: nouveau
	Kernel modules: nvidiafb, nouveau
01:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1)
	Subsystem: NVIDIA Corporation GP106 High Definition Audio Controller
	Region 0: Memory at ed080000 (32-bit, non-prefetchable) [size=16K]
		Status: D3 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
		Address: 0000000000000000  Data: 0000
	Capabilities: [78] Express (v2) Endpoint, MSI 00
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 75.000W
		LnkCtl:	ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
	Capabilities: [100 v2] Advanced Error Reporting
04:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02) (prog-if 01 [AHCI 1.0])
	Subsystem: ASMedia Technology Inc. ASM1062 Serial ATA Controller
	Interrupt: pin A routed to IRQ 125
	Region 0: I/O ports at d050 [size=8]
	Region 1: I/O ports at d040 [size=4]
	Region 2: I/O ports at d030 [size=8]
	Region 3: I/O ports at d020 [size=4]
	Region 4: I/O ports at d000 [size=32]
	Region 5: Memory at ed210000 (32-bit, non-prefetchable) [size=512]
	Expansion ROM at ed200000 [disabled] [size=64K]
	Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
		Address: fee002f8  Data: 0000
	Capabilities: [78] Power Management version 3
	Capabilities: [80] Express (v2) Legacy Endpoint, MSI 00
		DevCap:	MaxPayload 512 bytes, PhantFunc 0, Latency L0s <1us, L1 <8us
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
		LnkCap:	Port #1, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s unlimited, L1 <2us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
		LnkSta:	Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range ABC, TimeoutDis+, LTR-, OBFF Not Supported
		LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
		Status:	InProgress-
07:00.0 Ethernet controller: Qualcomm Atheros Killer E2400 Gigabit Ethernet Controller (rev 10)
	Subsystem: Gigabyte Technology Co., Ltd Killer E2400 Gigabit Ethernet Controller
	Interrupt: pin A routed to IRQ 18
	Region 0: Memory at ed100000 (64-bit, non-prefetchable) [size=256K]
	Region 2: I/O ports at c000 [size=128]
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
	Capabilities: [58] Express (v1) Endpoint, MSI 00
		DevCap:	MaxPayload 4096 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
			ExtTag- AttnBtn+ AttnInd+ PwrInd+ RBE+ FLReset- SlotPowerLimit 10.000W
		DevCtl:	Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 unlimited
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp-
			ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
	Capabilities: [c0] MSI: Enable- Count=1/16 Maskable+ 64bit+
		Masking: 00000000  Pending: 00000000
	Capabilities: [d8] MSI-X: Enable+ Count=16 Masked-
		Vector table: BAR=0 offset=00002000
		PBA: BAR=0 offset=00003000
		UESvrt:	DLP- SDES+ TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		AERCap:	First Error Pointer: 14, GenCap+ CGenEn- ChkCap+ ChkEn-
	Capabilities: [180 v1] Device Serial Number ff-bc-22-58-40-8d-5c-ff
	Kernel driver in use: alx
	Kernel modules: alx
08:00.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] (prog-if 00 [Normal decode])
	Latency: 0, Cache Line Size: 128 bytes
	Bus: primary=08, secondary=09, subordinate=40, sec-latency=0
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
		Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
	Capabilities: [88] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [ac] Subsystem: Device 2222:1111
	Capabilities: [c0] Express (v2) Upstream Port, MSI 00
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 25.000W
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 8GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
		LnkCtl:	ASPM Disabled; Disabled- CommClk+
		LnkSta:	Speed 8GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Not Supported
	Capabilities: [100 v1] Device Serial Number 48-f3-78-81-62-23-04-00
	Capabilities: [200 v1] Advanced Error Reporting
		UESvrt:	DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP+ Rollover- Timeout- NonFatalErr+
	Capabilities: [300 v1] Virtual Channel
		Status:	InProgress-
	Capabilities: [400 v1] Power Budgeting <?>
	Capabilities: [500 v1] Vendor Specific Information: ID=1234 Rev=1 Len=0d8 <?>
	Capabilities: [600 v1] Latency Tolerance Reporting
		Max snoop latency: 0ns
		Max no snoop latency: 0ns
	Capabilities: [700 v1] #19
09:00.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] (prog-if 00 [Normal decode])
	Bus: primary=09, secondary=0a, subordinate=0a, sec-latency=0
	Memory behind bridge: ebf00000-ebffffff
	Capabilities: [c0] Express (v2) Downstream Port (Slot-), MSI 00
			ExtTag+ RBE+
		LnkCap:	Port #0, Speed 2.5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
		LnkSta:	Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt+ ABWMgmt-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Not Supported ARIFwd-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
		LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
		Status:	InProgress-
			Status:	NegoPending+ InProgress-
09:01.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] (prog-if 00 [Normal decode])
	Interrupt: pin A routed to IRQ 17
	Bus: primary=09, secondary=0b, subordinate=24, sec-latency=0
	Memory behind bridge: dc000000-e3efffff
	Prefetchable memory behind bridge: 00000000d4000000-00000000d4efffff
	Capabilities: [c0] Express (v2) Downstream Port (Slot+), MSI 00
			ExtTag+ RBE+
		LnkCap:	Port #1, Speed 2.5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
		LnkCtl:	ASPM Disabled; Disabled- CommClk-
		LnkSta:	Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		SltCap:	AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+
			Slot #1, PowerLimit 0.000W; Interlock- NoCompl+
		Status:	InProgress-
09:02.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] (prog-if 00 [Normal decode])
	Bus: primary=09, secondary=25, subordinate=25, sec-latency=0
	Memory behind bridge: e3f00000-e3ffffff
			ExtTag+ RBE+
		LnkCap:	Port #2, Speed 2.5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
		Status:	InProgress-
09:04.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] (prog-if 00 [Normal decode])
	Bus: primary=09, secondary=26, subordinate=40, sec-latency=0
	Memory behind bridge: e4000000-ebefffff
	Prefetchable memory behind bridge: 00000000d4f00000-00000000d5ffffff
			ExtTag+ RBE+
		LnkCap:	Port #4, Speed 2.5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
			Slot #4, PowerLimit 0.000W; Interlock- NoCompl+
		Status:	InProgress-
25:00.0 USB controller: Intel Corporation DSL6540 USB 3.1 Controller [Alpine Ridge] (prog-if 30 [XHCI])
	Interrupt: pin A routed to IRQ 122
	Region 0: Memory at e3f00000 (32-bit, non-prefetchable) [size=64K]
	Capabilities: [88] MSI: Enable+ Count=1/8 Maskable- 64bit+
		Address: 00000000fee00298  Data: 0000
	Capabilities: [c0] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 <8us
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
		DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR+, OBFF Not Supported
		Status:	InProgress-
Remember to quote when replying or people would not see your reply
Btw it's an intel sound card which has the driver loaded and should completely be supported, my only guess is for some reason it's not set as a primary sound card
What happens when you look at System settings -> Sound
How many devices do you see in the "Output" list?
In this case you should not choose the one from video card, unless your headphones or audio appliance is connected through HDMI
I will do it from now on?
I have selected my headphones which are connected through the headphone jack on the back.
835113691_Bildschirmfotovom2019-02-1813-08-42.png.24eed6703db445339ef4c8e29db4ee6f.png
how do I change that?
I have selected my headphones which are connected thorough the headphone jack on the back.
Apparently it is set as the default device and should work
Is the output volume bar green?
Edited by Guest
I have changed my system language so that it is easier for you to see everything right away.
it's blue, but I it looks like your screenshot so I guess thats what you ment?1966914014_Screenshotfrom2019-02-1813-22-33.png.51d07a91b10f19a8485a7e32b6d54fd1.png
Also, does dmesg | grep snd show any output?
yes and it shows an error. Could that be the problem?
[    2.925304] snd_hda_intel 0000:01:00.1: Disabling MSI
[    2.925308] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    2.953606] snd_hda_codec_ca0132 hdaudioC0D0: autoconfig for Recon3Di: line_outs=3 (0xb/0x11/0x10/0x0/0x0) type:line
[    2.953608] snd_hda_codec_ca0132 hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.953609] snd_hda_codec_ca0132 hdaudioC0D0:    hp_outs=1 (0xf/0x0/0x0/0x0/0x0)
[    2.953609] snd_hda_codec_ca0132 hdaudioC0D0:    mono: mono_out=0x0
[    2.953610] snd_hda_codec_ca0132 hdaudioC0D0:    dig-out=0xc/0xd
[    2.953611] snd_hda_codec_ca0132 hdaudioC0D0:    inputs:
[    2.953611] snd_hda_codec_ca0132 hdaudioC0D0:      Mic=0x12
[    2.953612] snd_hda_codec_ca0132 hdaudioC0D0:      Line=0x13
[    3.041117] snd_hda_intel 0000:00:1f.3: Direct firmware load for ctefx-r3di.bin failed with error -2
[    3.624464] snd_hda_codec_ca0132 hdaudioC0D0: ca0132 DSP downloaded and running
It is missing a firmware...
Very strange it is not been added to Ubuntu...
Try downloading this >>> Here <<<, and put that file without changing the name in /lib/firmware with
cd *Downloadfolder*
sudo cp ctefx-r3di.bin /lib/firmware
Then reboot
Edited by Guest
5 minutes ago, Lukyp said:
cd *Downloadfolder*
Then reboot
Okay I have done that and have still got no sound, but the result from dmesg | grep snd changed.
[    2.868198] snd_hda_intel 0000:01:00.1: Disabling MSI
[    2.868205] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    2.881033] snd_hda_codec_ca0132 hdaudioC0D0: autoconfig for Recon3Di: line_outs=3 (0xb/0x11/0x10/0x0/0x0) type:line
[    2.881035] snd_hda_codec_ca0132 hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.881037] snd_hda_codec_ca0132 hdaudioC0D0:    hp_outs=1 (0xf/0x0/0x0/0x0/0x0)
[    2.881038] snd_hda_codec_ca0132 hdaudioC0D0:    mono: mono_out=0x0
[    2.881039] snd_hda_codec_ca0132 hdaudioC0D0:    dig-out=0xc/0xd
[    2.881039] snd_hda_codec_ca0132 hdaudioC0D0:    inputs:
[    2.881041] snd_hda_codec_ca0132 hdaudioC0D0:      Mic=0x12
[    2.881042] snd_hda_codec_ca0132 hdaudioC0D0:      Line=0x13
[    3.556279] snd_hda_codec_ca0132 hdaudioC0D0: ca0132 DSP downloaded and running
[   21.788013] snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 85
So it still does not work even if you click to "test speakers"?
If not download pavucontrol "sudo apt install pavucontrol"
open pavucontrol
If you try open a youtube video for example
Does it show your correct sound card? And it it not muted?
The last thing I would try is to download an updated linux distro like Manjaro linux and try it in a usb live, it it does work you could need to update the kernel in Ubuntu by using ukuu and using some updated kernel possibly the same manjaro uses
Edited by Guest
that is correct
I think that is the right one yeah and it's not muted.281454677_Screenshotfrom2019-02-1814-01-12.png.9b29058ec282aacca0282c45eaee2d95.png
that is correct
I'm a bit clueless tbh
as last thing try to change the profile here to something that looks reasonable
If you got a fast internet connection and a ready to use usb, download manjaro linux and try in a live usb if it does work
If you does not have one, try installing Ukuu then open it and install the most recent kernel you can, reboot and choose it
sudo apt-add-repository -y ppa:teejee2008/ppa
sudo apt update
sudo apt install ukuu
Btw now that I notice it is not using the same common realtek sound card codec, but rather a strange Creative sound blaster one called ca0132 and there seem to be a lot of people with the same issue, they say it's fixed to the newer Linux versions
Edited by Guest
Okay I changed it to analog stereo output with no result.
I will report back to you. give me a few minutes.
I can confirm it's a bug that has been fixed to Linux version superior to 4.20, so I would use ukuu and manually update to 4.20.10
If you don't want to update there are some workaround you can try to get the sound card work correctly
Edited by Guest
sigh... so after some struggle in the beginning i managed to update the kernel but it is still silent. so I think I will have to give the workaround a shot.. but at least I can enable the audio in the alsamixer now. But after a reboot it's silent again... can the workaround fix that or was it just get the audio working at all?
Edited by losBaumos
So you have installed the 4.20.10? You need to also boot from it, by default it should, you can check through a terminal with "uname -a"
It should work...
Btw the workaround they say is to use a CLI hybrid GUI utility called alsamixer (that is different from pulseaudio you typically use) and unmute all the things you can with "M"
Yes I am running 4.20.10 now.
It should work...
At least I can enable the audio now but I have to do it after each reboot again.
1 minute ago, losBaumos said:
At least I can enable it now but I have to do it after each reboot again.
Enable what?
I explain, grub will boot by default the latest kernel, unless you say otherwhise by clicking to "advanced linux version", to make sure you are running it just use uname -a so by default it will boot 4.20.10 anyway
Btw you can try the alsamixer workarounds
If still it doesn't work try removing the firmware which is probably not needed sudo rm /lib/firmware/ctefx-r3di.bin
Edited by Guest
1 minute ago, Lukyp said:
Enable what?
sudo alsactl store
  • 1 year later...
On 2/18/2019 at 7:32 AM, Guest said:
dmesg | grep snd shows output:
cd *Downloadfolder*
Then reboot
THIS ^^^ is what got analog audio working on my clean-install Mint 20 MATE system.
Unmodified Gigabyte Z170X-Gaming 7 board w/i7-6700K.
The only other thing I had to do was to open up alsamixer and switch from "Line Out" to "Headphones"
Thank you, o anonymous Guest!
