Hi, not sure if I'm posting this in the correct thread but I'll give it a shot in here.. (sorry for long post) (I've posted this in other threads since I'm not sure where to post it)
I just recently built myself a new gaming PC (on the high end).
CPU: i5-9600K
GPU: Asus RTX 2070
RAM: 16GB Corsair DDR4 3200Mhz
Motherboard: Asus Prime Z390-A
The issue is that no matter what setting I use, my OBS/stream keeps lagging like crazy (15-30 fps, sometimes down towards  8-12 fps). But I'm not dropping ANY frames whatsoever.
CPU is barely breaking a sweat. Working at maybe 20-30%, but mostly down at 10%.
I've got a 60/10 connection and according to the tests, there's no issue with the broadband.
If I try to stream with 1080p @ 60fps. The stream lags. If I stream with 720 @ 60FPS. The stream lags.
Changing the settings down to 30 fps doesn't change a thing.
Pushing it to NVENC instead of x264 does absolutely nothing.
Bitrate is just fine and I'm not getting ANY lag in-game.
Does anyone have any idea how to fix this?
https://linustechtips.com/topic/1034393-streaming-problems/
3 minutes ago, immaguy1234 said:
I just use Nvidia Shadowplay, I find that it works better than OBS for me.
Yeah, if I use Nvidia Shadowplay I get no issues at all.
Problem is, I should be able to use OBS and all it's widgets to stream properly with my setup.
Switching to Shadowplay just isn't an option TBH.
I built a gaming PC for 2K$ and I want it to work properly..
https://linustechtips.com/topic/1034393-streaming-problems/#findComment-12306647
-= Moved to Troubleshooting =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1034393-streaming-problems/#findComment-12306669
